Is my power normal??
Old Jan 9, 2013 | 01:46 PM
JohnBradley's Avatar
Whats the timing and AFR doing past 7,000r? The graph is so smooth its hard to tell whats happening.
Old Jan 9, 2013 | 02:10 PM
TURBO_S2K's Avatar
AFR is 11.4-11.5 past 7000rpm
Timing is 11 at 7000 and between 12-13 at 8000
Old Jan 9, 2013 | 08:18 PM
I guess the next question is what fuel (octane level) and if you are logging backpressure? The 1.0 A/r divided wont max out at 20psi. I have ran the 0.84 divided on a 6262 to 27psi and only saw 34psi of backpressure. That also made 570whp/480 torque.
The timing is pretty high for 10.7:1 compression on normal pump fuel based on my experience. I have been at 9* or so on 10.5:1 motors at 8000 on 92 (97 RON) and 19psi and been on the edge of knock.
Most likely it is a combination of small cams and a stock intake manifold. I think the dyno graph makes it look more pronounced compared to the indicated 60hp drop from 7k to 8k at the bottom of the sheet.
I have seen similar decreases on cars before, normally stock cam IX's with a stock turbo on E85 but the ratio of loss will stay similar.
Old Jan 10, 2013 | 02:10 AM
TURBO_S2K's Avatar
My tuner said if he lowers the timing he is losing power
I ordered new cams (Kelford 276/272 High Lift)
and a Magnus V5 Intake Manifold w/ 75mm TB
Hopefully it will fix it...
Old Jan 10, 2013 | 05:26 AM
foxbat's Avatar
You already have 270 cams! Can't imagine any benefit of bigger cams & manifold while your boost is only at 20 psi!!!
Old Jan 10, 2013 | 06:32 AM
TURBO_S2K's Avatar
I am not trying to make more power. I only want to keep the powerband after 7000rpm
There is a huge decrease in power (almost 100awhp) after 7000rpm
Old Jan 10, 2013 | 06:56 AM
RussellDaniel's Avatar
That intake manifold that your getting will def help it breathe up top. Tune for e85 if it's available.
Old Jan 10, 2013 | 02:17 PM
foxbat's Avatar
Does your boost remain at 20psi after 7000rpm or does it taper down?
Old Jan 10, 2013 | 02:47 PM
TURBO_S2K's Avatar
it stays there...
Old Jan 10, 2013 | 03:37 PM
foxbat's Avatar
Hmm, very strange! The only thing I can think of is high temperatures causing loss of efficiency at high RPMs. What kind of intercooler +piping do you have? Also, have your tuner check IAT level at high RPM.
But I still don't think that larger cams would do you any good, Tomei 270 are excellent cams, JB mentioned power loss cases with stock cams.
TheBoz
Mar 7, 2016 07:54 AM
r34p3rex
Apr 12, 2015 02:49 PM
dnetcrawler
14
May 14, 2013 10:26 AM
GK007
Apr 3, 2013 01:58 PM
SoCalRedLine
35
Sep 30, 2007 08:43 AM
