Evo won't shift
Old Jan 13, 2013 | 07:09 PM
murkdevo's Avatar
Evo won't shift
I have an 03 evo and it started not going into 2nd. I pulled the trans out and had it rebuilt. I can air shift it into every gear fine. When I hook up the linkage the brackets hit each other and it won't go into 2nd, 4th, and reverse. The bracket that holds the white shoe appears to be too low and doesn't properly seat onto the piece in the trans. I'm not sure if I bent something or what's going on. Has anyone else had this problem?
Old Jan 14, 2013 | 11:25 AM
BEKevo's Avatar
http://www.jackstransmissions.com/pa...install-damage
Maybe installation error??
Old Jan 14, 2013 | 11:57 AM
rmorr79's Avatar
I had a similar problem after a transmission swap in my old talon. It wouldnt go into 1st, 3rd or 5th. My problem had to do with the trans cables being messed up. did you try shifting the trans by hand?
Old Jan 14, 2013 | 12:50 PM
BEKevo's Avatar
Also what "white shoe" are you talking about?
Old Jan 14, 2013 | 08:55 PM
murkdevo's Avatar
It shifts great by hand which makes me think the trans is fine. It's only with the bracket on the bottom that it bumps into each other.
The white piece looks like a rectangle with a piece cut out of it.
Old Jan 14, 2013 | 10:53 PM
BEKevo's Avatar
I understand now.. Could you post a pic of the brackets while there's interference (ie touching).
playmajohn
22
Jun 13, 2017 11:47 AM
Malfury
Feb 21, 2015 11:25 AM
mshilto89
23
Feb 6, 2013 04:14 PM
Darkn3s
12
Oct 18, 2012 11:34 AM
