lean afr's when switching injectors
Old Feb 6, 2013 | 07:34 PM
  #31
03evilution's Avatar
From: Poughkeepsie NY, Central Jersey Shore, Fort Meade MD
Originally Posted by JohnBradley
You are over running the regulator by 35psi. The coil of the injector cant open against the head pressure and the car idles dead lean...opposite of what you would think would happen.
Choice is wire the second pump on a hobb, wire the pumps to the factory wiring so that the 9v-14v crossover works at idle.
Then proceed to tune.
Not sure why it didnt do this to you last year but it should have been.
Aaron
But why does it idle on the stock injectors and not the 1350's? Would buying an aftermarket fpr help with this issue?
Either way I will take power off one of my pumps today when I try the larger injectors again to see if my issue resolves itself. If so ill just order a hobbs switch as you have reccomended since its a non expensive fix.
Old Feb 7, 2013 | 10:49 AM
  #32
fastyouth1313's Avatar
i would disconnect one of the pumps then try, if it still leans out then change the maf vs coolant table like stated before.
Old Feb 7, 2013 | 12:43 PM
  #33
JohnBradley's Avatar
That I am not sure 100%. I just know I have run into this before and that was the cause.
The other time you can see it is the crossover on the the second pump kicking being too low and the fuel pressure is too high. Some kits would kick on at 2-3psi where it needs to be 7-8 and you find a really bad misfire because the car is temporarily lean right where it cant be (in boost).
Old Feb 7, 2013 | 03:53 PM
  #34
so i took power off the second pump and changed the maf comp vs coolant temp and car now idles. thanks for the help guys.
so what size hobbs switch do you recommend...7 psi?
Old Feb 7, 2013 | 04:11 PM
  #35
yeah the low pressure is 0-15psi and we usually set it around 7-8 and it seems to make it pretty invisible as it transitions on.
Old Feb 7, 2013 | 04:23 PM
  #36
Your welcome brother!
Old Feb 7, 2013 | 04:36 PM
  #37
Aswome thank u both
Old Feb 8, 2013 | 09:13 AM
  #38
actually i do have one more question...i dont believe my pump that i have on for idle is wired to the resisted stock power suppy...what color wires in the stock harness are the power and neutral so i can wire that correctly?
Old Feb 8, 2013 | 09:17 AM
  #39
https://www.evolutionm.net/forums/ev...mp-rewire.html
im at work again and alot of info is blocked for me. but i think this might help.
Old Feb 8, 2013 | 11:13 AM
  #40
So i went ahead and rewired one of the pumps back into the white wire on the harness and once the hobbs gets here ill wire the second pump back up...thanks again
Old Feb 8, 2013 | 11:27 AM
  #41
just curoius....
whats you full operating temp AFR's? with they was your set up now?
Old Feb 8, 2013 | 11:57 AM
  #42
Originally Posted by fastyouth1313
just curoius....
pm me your email and ill send you a log of my car
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
cplillges
May 25, 2017 04:33 AM
TheBigD
Oct 5, 2012 08:07 PM
Khalid
Jun 11, 2008 03:19 AM
