Evo IV-IX transmission and transfer case
Old Feb 7, 2013 | 12:25 AM
BrunoBoy650's Avatar
Hi, so I'm doing a auto to manual swap on a 4G64 hybrid and need to know if the IV transmission and VIII are the same? I mean do they use the same mounts and axle sizes? Also is the transfer case the same ? Will a IV transmission work with a VIII x case? Thanks
-shane
Old Feb 7, 2013 | 12:27 PM
Anyone?
Old Feb 7, 2013 | 04:01 PM
Yogi_B's Avatar
Transmissions are interchangeable and evo4-6 and evo 7-9 transfer cases will bolt up, they have the same mounting face.
What you can't do is bolt an evo 7-9 transfer case to an evo 4-6 and vice versa due to different sub frame design.
Old Feb 7, 2013 | 04:05 PM
My set up isn't going into a lancer or mirage or Evo. But what you are saying is that the trans 4-9 are all exactly the same correct ? Mounting and figment wise. And if I use a 4 trans I can bolt on a 8 TransferCase and it'll work yes?
Old Feb 8, 2013 | 11:57 AM
blowngasket's Avatar
the 5 speed trans are the same trans w5m51 the Tcases are different thou.Why not make it easy and get a good W5m51 5 speed and a 03-06 Tcase non ACD? I dont think the earlier Tcases were any better then the 03-04 Tcases with exception to the 04 RS tcase of course.
Old Feb 8, 2013 | 12:54 PM
Yogi_B's Avatar
The evo4-6 transfer cases have the output on the bottom while the evo7-9s have it up the top, which is why they are not interchangeable, even though they do bolt onto the gearbox.
Old Feb 8, 2013 | 01:33 PM
I'm going with a Evo 4 trans and Evo 8 case if that works. Thanks.
Old Feb 8, 2013 | 08:08 PM
chrisff521's Avatar
I have a 5 tranny in my 8. Same thing. Transfer case is shaped different
Old Jan 10, 2018 | 04:38 PM
LJ7two4's Avatar
So I can use an evo 4 transmission and tcase with an evo 8 motor? I am looking into this as I need to replace my motor...
I have a lead on an evo 8 block and could just put the evo 4 head on that...probably less work?
aggieEVO
Feb 23, 2023 08:26 PM
LJ7two4
Jan 15, 2018 08:01 AM
SaulHudson
Nov 10, 2017 06:35 AM
umarkhan102
Mitsubishi TC-SST Discussion
Apr 18, 2017 04:48 PM
eddy5201314
Nov 9, 2016 10:47 AM
