Walbro 485 limits
Old Feb 7, 2013 | 02:33 PM
nikg's Avatar
Walbro 485 limits
Has anyone really tested the limits of this pump on E85 to the point where the fuel pump couldnt keep up?
searched and didnt come up with much.
Old Feb 7, 2013 | 02:35 PM
evoredy's Avatar
https://www.evolutionm.net/forums/ec...-you-want.html
Old Feb 7, 2013 | 02:56 PM
nikg's Avatar
Thanks for the reply.
That thread was tough to follow. Looks like you are still using a 255 pump. Im looking for results with the walbro 485.
Old Feb 7, 2013 | 03:36 PM
evoredy's Avatar
It's a walbro "485."
The nov7 log shows the fuel starvation at 5-7K. Basically about 500whp (dynojet) on e85 with stock wiring and fuel lines.
Old Feb 7, 2013 | 03:47 PM
nikg's Avatar
Wow really thats crazy. Seems like you might have some other issues with your fuel system. Im running a 4 year old single wablro 255 on e85, stock wiring and lines and have had many virtual dyno graphs reading over 600 whp dynojet, and just under 600 whp corrected on a mustange dyno.
Old Feb 7, 2013 | 04:37 PM
heel2toe's Avatar
600whp with a single 255 on e85? What injectors are you using? Even so I didnt think a 255 could support nearly that much on e85.
Old Feb 7, 2013 | 04:58 PM
nikg's Avatar
Yeah really shouldnt be possible but it is what it is. FIC 1350cc injectors. Its definitely fully tapped out and loses pressure up top. I think a big factor is it makes this power under 30psi which keeps peak pressure down.
Old Feb 7, 2013 | 05:21 PM
evoredy's Avatar
It's pointless to argue virtual dyno graphs. That's why I posted logs. Do you have any? I'm going to say the 600 whp on a 2.0 [E85] with a single wally is well...quite uncanny.
Old Feb 7, 2013 | 05:44 PM
nikg's Avatar
Of course i have logs but Im really not worried about what my 255 is currently doing I have been through this before. I was just trying to make a point that your 485 should not be close to maxed and there must be a seperate issue.
Old Feb 7, 2013 | 05:56 PM
nikg's Avatar
so based on this thread I just found https://www.evolutionm.net/forums/ev...r-awesome.html.
This car makes around 650 dynojet on a standard 400. So the 485 which flows a little more I would think would do atleast 700.
I mean those are all just dyno numbers. I just want to see if i can hit my power goal with the 485.
Old Feb 7, 2013 | 06:44 PM
evoredy's Avatar
Good luck.
Old Feb 8, 2013 | 12:02 AM
mrfred's Avatar
Sorry, but not possible. A walbro 255 cannot even flow 600 whp of e85 at 0 psi of boost and 14 V.
badandy
May 10, 2020 12:20 PM
Gruppe-S
Gruppe-S Engineering - California
16
Jan 21, 2014 08:44 AM
Jamessvt2004
AEM EMS
26
Jul 5, 2012 10:12 PM
twinturbogreg
Aug 30, 2011 07:24 AM
mtm864
Apr 18, 2011 01:46 AM
