FP Black possible shaft failure :/
Old Feb 15, 2013 | 08:45 PM
EVOWRC111's Avatar
Well after replacing my O2 housing bolts and gasket I decided to try and test my semi-new FP Black on my Evo 9. Anybody out there have the same amount of play. I wanna say its between 1/16 and 3/32s play horizontal.
http://www.youtube.com/watch?v=jlccC...ature=youtu.be
Old Feb 15, 2013 | 08:50 PM
batty200's Avatar
Definitely thrust failure. If FP won't Rebuild it look for a Mellett thrust bearing. It is the same style stainless thrust washer.
Old Feb 16, 2013 | 03:35 AM
bbyevo8u's Avatar
that sux! how many miles on it?
Old Feb 16, 2013 | 01:42 PM
stunt2's Avatar
seen crankwalk
now this is a shaftwalk
sorry for you
Old Feb 16, 2013 | 03:13 PM
PatricksEvilEvo's Avatar
Yea that's quite a bit. Reason why I won't go with an FP bigger than the red.
Old Feb 16, 2013 | 03:18 PM
EVOWRC111's Avatar
It has 5,882 miles on it. Its never been on a track but its been on a dyno at Yimi Sport Tuning.
Old Feb 16, 2013 | 03:23 PM
bdonIX's Avatar
thats a lot of movement.
Old Feb 16, 2013 | 03:32 PM
Svendiesel's Avatar
FP's lack of warranty and slow service is why I ditched my FP turbo and will never buy one again.
Attached Thumbnails FP Black possible shaft failure :/-nostalgiatopfueler-explosion.jpg
Old Feb 16, 2013 | 03:38 PM
17pstockcar's Avatar
I thought fp had a good warrenty expcially with the bb and oil feed lines?
Old Feb 16, 2013 | 04:00 PM
Svendiesel's Avatar
From what Ive read and my personal experience, they basically offer their warranty and will warranty IF they deem the issue to be worthy of a warranty.
So even if the turbo failed at their own fault, they will say something else caused it. User/install error, improper oiling, yadda yadda, etc etc
Old Feb 16, 2013 | 10:30 PM
xXANCHORMONXx's Avatar
jeez thats alot did you start it up correctly by disconnecting the crank sensor to run the oil pump? What oil is used and when have you change it?
Old Feb 17, 2013 | 08:38 AM
pupo's Avatar
Is that a BB FP black or JB?
Old Feb 17, 2013 | 10:49 AM
EVOWRC111's Avatar
Ball bearing....
Old Feb 17, 2013 | 10:54 AM
EVOWRC111's Avatar
I used AMS oil engine break in oil, and yes I cranked it for over 15 seconds with video proof just in case I were to have issues with my new MAP stg 2 engine.
Old Feb 17, 2013 | 10:56 AM
EVOWRC111's Avatar
To my understanding BB turbos can not be rebuilt. The complete center cartridge must be replaced. Can anyone else confirm that?
