Clutch slippage and other stupid questions...
Ok, to start off, the problem that I'm having is that on my Evo 9 (5 spd), the clutch started slipping last night. It's mostly noticeable in 3, 4, and 5th gear. It starts at around 2800 rpm and grabs again after about 1-2 seconds. As far as I know, the clutch and the drivetrain are completely stock. In fact, the car itself is completely stock except for the radio and tires. I was thinking about taking a look at all of the cylinders, lines, and fluid tomorrow or Tuesday just to make sure there's no leaking. Could the slippage be caused by something else OTHER than the clutch needing replaced? I almost want to bleed the thing but I'm not sure where the slave/master cylinder reservoir is. Can anybody shed a little light on my problem? The car just hit 87k miles. Any words of wisdom will be appreciated?
How many miles are on the car/clutch? I haven't experienced any cylinder problems at all on these cars, unlike my previous dsm's
I'd say yea your clutch, like he said above, that's when you're making the most torque.
EDIT derp missed the 87k mile part, yea I'd definitely say clutch. I used and had amazing luck with my Exedy stage 1 if you're planning on keeping it mostly stock for a while. It's inexpencive and takes some crazy abuse with ease.
I'd say yea your clutch, like he said above, that's when you're making the most torque.EDIT derp missed the 87k mile part, yea I'd definitely say clutch. I used and had amazing luck with my Exedy stage 1 if you're planning on keeping it mostly stock for a while. It's inexpencive and takes some crazy abuse with ease.
I figured as much because that's when the turba'puffer kicks in and makes the boost. I'm coming to terms with replacing the clutch and I'm thinking of going with the Excedy Stage II clutch (through AMS Performance) when I get the money. Even though it's my daily driver and it's completely stock now, I'm planning on doing a few performance mods and only looking to make about 350 block lb-ft of torque. Anybody have any tips on where the reservoir is so I can bleed the cylinders? Also, anybody have a good idea on when I should expect on labor costs for replacing the clutch?
But even though everywhere I've read with the same problems says it's the clutch, I still want to run through most of the typical things that I can adjust/bleed/fiddle with before I spend the money on the clutch. Also, I need to adjust the clutch because I have the "abnormal but normal" click/stick into 1st, 2nd, and sometimes 3rd gears.Also, I saw the Exedy stage I but just for a few more dollars I can get the stage II just in case later on down the road I want to go past the 350 lb-ft mark and not have to go back into the thing. Thanks for the advice, though!
Haha, it's ok. Selective seeing runs in my family.
A clutch install just labor will run you about $500-$600 then you have to get the flywheel resurfaced and pay for the tcase, trans, and acd fluid if you have it.
The exedy stage 2 is a puck clutch, probably not something you want on your street driven Evo. Look into the new Competition 3000lb single plate clutches, that's what I'm going with and I should be around 400wtq/400whp. Personally I'll never get a puck clutch. Try adjusting it, the adjuster is right on the back of the peddle but I'm still going to say the clutch is probably shot. You'd be able to tell if it needed an adjustment, there would be too much play in your peddle before engagement and disengagement.
The Exedy stage 1 held 360ft lbs for me no problem, about 60 or so launches and 3 years/35k miles of hard street use/launches and it still grabs and doesn't slip to this day.
Describe the "click/stick" to me. I have a Competition Clutch stage 2 and I'm making 323whp 315 ftlbs on a Mustang dyno.
http://www.lancerregister.com/showthread.php?t=123535
And I don't mind about the other things like the flywheel (as long as it has enough meat on the bones) and fluids.
MitsuJDM
19
Nov 9, 2016 03:47 PM
RCEsterly
11
Sep 3, 2012 10:08 PM
Codevo
Oct 7, 2008 06:15 PM
