Open the hood and theres oil everywhere!
Old Feb 18, 2013 | 07:40 PM
Fishd0's Avatar
That wouldnt suprise me. When i got it the boost solenoid wasnt hooked up
Fishd0's Avatar
Im on a phone and cant figure out how to upload pics
Old Feb 18, 2013 | 07:56 PM
Fishd0's Avatar
The pcv is good
Old Feb 18, 2013 | 08:37 PM
tehhobbs's Avatar
If the PCV is indeed functioning properly I would look into having a leakdown test done on the motor, might be a sign of a larger issue.
Old Feb 18, 2013 | 09:28 PM
Fishd0's Avatar
I will do a leak down test tomorrow. Any other ideas as to what could cause this?
Old Feb 19, 2013 | 06:46 AM
tehhobbs's Avatar
There's only a few reasons why you would have so much positive pressure in the crank case either the PCV valve or compression from the cylinders are leaking past the rings/headgasket/valve stem seals. With that said I had a built SR that would throw a quarter of a quart of oil all over my engine bay after a night of hard driving, compression was fine along with leakdown. Installed a vented catch can setup and was regular about emptying it.
Jaxson75
Lancer Engine Tech
10
Feb 11, 2016 05:11 AM
jarek0621
24
Dec 3, 2015 03:26 PM
Kmac
Jul 13, 2008 09:46 PM
talentsearch301
Jan 29, 2007 07:59 PM
evoinit
Jul 3, 2004 10:25 AM
