Tapping Evo9 thermostat housing for an additional 1/8" NPT coolant temp sensor?
Old Aug 7, 2013 | 02:33 PM
  #31
EGbeater's Avatar
Originally Posted by browningderek
Ya know.... an easy way to add a sensor is make a metal pipe to put in your upper rad hose. The just weld a bung to it. Done.
I wasn't looking for the easiest way to add a coolant temperature sensor; I was looking for the best way to do it.
From my very first post in this thread:
Originally Posted by EGbeater
I know it's possible to install a coolant temp sender in the radiator hose with an adapter available from Prosport or Greddy, but I'm not a fan of that method for two reasons:
  • In the case that the thermostat sticks shut (or partially closed), I won't know I have a problem
  • Cutting into the radiator hose to install the adapter adds two full hose-circumference areas of potential leaks
And from just a few posts up:
having the sender in the top half of the T-stat housing means you're reading temps AFTER the thermostat. In the rare situation that the thermostat sticks closed, your coolant gauge will be reading cold/normal temps, while your engine will actually be massively overheating. Not what I wanted.
There is a very good reason Mitsubishi put their coolant temperature sensor in the BOTTOM of the thermostat housing, before the thermostat, and not after it.
Old Aug 7, 2013 | 02:42 PM
  #32
browningderek's Avatar
Yea I gotcha man. But that is the right way.....once the thermostat opens there will be no difference in temp reading in either location. What I meant was I think your making it more complicated that it needs to be.
Old Aug 7, 2013 | 02:43 PM
  #33
Leave the stock sensor where it is.....
Old Feb 23, 2015 | 06:54 PM
  #34
1BadEv0's Avatar
Thank for this, it helped a lot and made it so easy to get done!!!
Old Mar 1, 2015 | 09:52 PM
  #35
EGbeater's Avatar
You're welcome; I'm glad it was helpful to you. I'm honored this thread compelled you to make your very first post to evom.
EGbeater
Aug 6, 2021 05:47 AM
EGbeater
28
Jul 18, 2019 01:24 PM
EGbeater
Sep 19, 2016 05:50 PM
EGbeater
Jul 23, 2016 08:16 AM
SuperHatch
Jan 23, 2006 07:36 PM
