gsc s2 vs gsc s3?
Old Mar 6, 2013 | 04:45 PM
ctfpevoVIII's Avatar
gsc s2 vs gsc s3?
well first of all I was kind of bummed because I was waiting for over 3 months for the s2's that are still back ordered. I have decided to go with the s3's and will have them in a day or two, I hope I have made a wise decision? Can't wait to get these installed with my stock ported im and new throttle body.
Old Mar 6, 2013 | 05:05 PM
Czarcasm's Avatar
Not trying to bash but is that a question or opinion?
Ill be the first one to say it depends on your build and where you want to be at power wise
Old Mar 6, 2013 | 05:19 PM
evo unknown's Avatar
My GSC S2s matched up real nicely with my BBK Full. I think you have made a good decision and they will be a good fit with the BB-BBK-B! Post up results asap!
Old Mar 6, 2013 | 05:23 PM
Supergoslow's Avatar
https://www.evolutionm.net/forums/ev...vs-gsc-s3.html
check out the dyno sheet by english.
A good engine making a lot of power needs the right combination that's what my pops always told me.
Old Mar 6, 2013 | 05:24 PM
I was leaning more toward opinions. I know the s2 is a great cam from what I have read, but I no longer want to wait and once I read about how the s3's worked on stock turbo/2.0 engines I was in. I don't mind trading a little slower spool for some better top end.
Old Mar 6, 2013 | 05:27 PM
I plan on posting the results as soon as their installed and re-tuned
Old Mar 6, 2013 | 05:31 PM
tscompusa's Avatar
the s3's will make more uptop then the s2. i have posted multiple comparisons and examples of what s3's do vs stock cams and vs kelford 272, and so forth. you did not make a bad decision. for the minimal amount of lag downlow you gain a lot more top end. just make sure you have a good set of springs/retainers preferably GSC beehive or Kiggly beehive.
Old Mar 6, 2013 | 05:51 PM
Thanks Tom. Yeah I did read some of your threads about the comparisons you posted and after reading them it made my decision that much easier. I ended up buying the supertech's duals /retainers with seals, how do these compare to the others you mentioned ?
Old Mar 6, 2013 | 11:48 PM
sktng22's Avatar
supertech duals will work.
Old Mar 7, 2013 | 04:52 AM
tscompusa's Avatar
supertech duals will work, but make the valvetrain alittle noisier then the ones i mentioned. I used the supertech duals on the s3's for awhile, but now switching to kiggly beehives.
Old Mar 7, 2013 | 06:39 AM
fqjdmct9a's Avatar
Just curious how do the Cosworth M2 compare to the S2?
Highbooost
Jun 28, 2017 08:29 AM
Slow_Supra
Jan 8, 2017 09:24 AM
EVO 4 life
Nov 19, 2016 08:30 PM
evo8vz
Oct 18, 2016 06:48 AM
3bar_dc2
Feb 9, 2016 09:45 AM
