Ported turbo, no boost... HELP!!
Old Mar 18, 2013 | 11:54 PM
slc_evo69's Avatar
So here's the deal, just had my exhaust manifold and turbo ported by Buschur. I put it all back in today, along with an aftermarket MAP rev2 o2 housing. Everything seems to be installed correctly, nice and tight.
No oil or coolant leaks, just MAJOR boost creep. WHY?
I'm completely stock besides catback exhaust and a fuel pump.
Turbo doesn't seem to want to spool until a very high RPM, and when it does it's a lot less pressure than it use to be.
Can anyone shed some light? Boost leak tests, etc? PLEASE HELP.
Old Mar 19, 2013 | 12:07 AM
DsmGuy86's Avatar
You check the pre load in the wga, and the boost creep issue can be because of the porting I've noticed it happen a lot a 3 port can help keep that under controll.
Old Mar 19, 2013 | 12:28 AM
BEKevo's Avatar
Did you get a tune after the porting?
Old Mar 19, 2013 | 05:59 AM
slc_evo69's Avatar
Nope, no tune. Is this my problem?
Old Mar 19, 2013 | 07:15 AM
evo8426's Avatar
How large is the hole in the o2 housing where the sides merge together? If it is too small it will cause boost creep. Check the pics in this thread to see what hole I'm talking about. https://www.evolutionm.net/forums/ev...gate-port.html
The "no tune" part is not the reason for your problem.
Old Mar 19, 2013 | 10:03 AM
slc_evo69's Avatar
The hole is pretty big actually.
Now that I have done a little more research I'm beginning to think it is more of a boost leak, instead of boost creep. The turbo seems to not want to spool at all (little to no pressure showing on boost gauge), and I feel almost no pull compared to the pull I had before I took the turbo out to be ported. Nor am I hearing much of a blow off like I use to.
I was sure to re-connect and tighten intake, j-pipe, vacum line, EM, o2 to DP (any place I could be leaking).
I also was sure to check all intercooler piping connections.
Maybe a boost leak test is appropriate?
I'm just mind boggled, I always thought porting caused a quicker spool. And I'm getting opposite results
Old Mar 19, 2013 | 10:32 AM
ILuvJDM's Avatar
check all the little things first. Everything that was disturbed during the removal/install. This includes the wastegate preload, boost controller vacuum lines, etc..
Old Mar 19, 2013 | 12:25 PM
evo_yoshi15's Avatar
Jst Go Thru AndDouble Check Everything Take It Apart If U Have To Good Luck
Old Mar 19, 2013 | 12:38 PM
zenoise's Avatar
This. Specially b.c. lines.
Old Mar 28, 2013 | 09:12 AM
slc_evo69's Avatar
Turns out it was the WGA, now holding boost and spooling up after adjustment
I will still be running a boost leak test this weekend though, figure it won't hurt.
Thanks guys!
Pure EvoIX
Apr 7, 2026 12:16 AM
EVOIXreno
Oct 3, 2014 03:40 AM
whotippedmycow
May 28, 2014 12:47 PM
Eartears
40
Feb 15, 2013 10:10 AM
