TB help
Old Mar 30, 2013 | 01:32 AM
bluedemon199's Avatar
TB help
I have been reading both negative and positve thins about the boomba 75mm I currently have br uicp do I need any adapters also can you guys give me your feed back about it
Assuming just. 3"-2.5" coupler
Old Mar 30, 2013 | 02:55 AM
bump
Old Mar 30, 2013 | 07:25 AM
Bump
Old Mar 30, 2013 | 08:28 AM
Bump
Old Mar 30, 2013 | 10:56 AM
304MR's Avatar
Are you at the stage where you need a 75mm tb?
Imo I would go with a ported stock vs the aftermarket. Any aftermarket tb's that I've run always have driveability issues. With that said, I've never run a boomba.
Maybe add your mods and what your intentions are with the car.
Old Mar 30, 2013 | 11:03 AM
PatricksEvilEvo's Avatar
I've heard bad things about all the aftermarket tb's, especially the Boomba. No personal experience but I've been told by reliable sources that drivability sucks and it's cheaply made. Look into Buschur's ported stocker.
Old Mar 30, 2013 | 11:08 AM
meckert's Avatar
^^^ and also all you will do is run into a road block at the manifold which will also need to be ported-- no sense in doing one without the other--no benefit.
Old Mar 30, 2013 | 11:16 AM
minimarine09's Avatar
^^^ that
Old Mar 30, 2013 | 11:33 AM
I bought becuse evi also bought a DI intake and thoutbincild benefit from it
Old Mar 30, 2013 | 11:50 AM
EvoJoeIX's Avatar
Ive heard aftermarket throttle bodies can have a lot of drivability issues. Makes me hesitant to get one. I run a 65mm now
Not to steal the thread, but at what point is a 65mm tb becoming restrictive? I mean AWD motorsports car went 8's on a ported stock intake manifold and a 65mm throttle body
Old Mar 30, 2013 | 11:56 AM
I the stock TB a 5.0 bolt pattern?
Old Mar 30, 2013 | 12:12 PM
Teal2nnr's Avatar
I believe there was a thread about this (there have been many) a few weeks ago. A 65mm TB is basically good for 95% of the owners on here, going bigger although allowing more air in makes your throttle response lag quiet a bit (as you can imagine). Also if you’re going that big I hope you have a missive intake mani, as it would be pointless to do this on a stock IM.
Someone either Englishracing or BR did a test where they went from a 65mm TB 2.5” intake piping to a 75mm TB and 3” intake piping, and i believe the gains were marginal (8whp or something). Hopefully I’m not talking out of my *** here since I’m just going off of memory. Just food for thought.
Old Mar 30, 2013 | 12:24 PM
It would be going on a driven innovations mani
Old Mar 30, 2013 | 09:06 PM
Any comments on the 75mm with the DI intake?
Old Mar 30, 2013 | 09:34 PM
this quote is from the BR website when you go to buy their ported TB 65mm-
"Through extensive dyno testing we've found that even up to 700+ whp the Buschur Racing 65 mm throttle body provides the best power throughout the entire power band. This testing was done with throttle bodies up to 3.25" all being beat by the smaller 65mm unit. No gains were had anywhere in the powerband by going larger"
OP- im not 100% but, im sure they did that test with their ported stock IM. so idk how the results would turn out using an after market IM.
But me personally, i think just the drive-ability factor alone out weighs the amount of power made by it. just my 2 cents!
cleudson
Oct 4, 2013 07:47 AM
danextreyes7
17
Nov 12, 2011 01:34 PM
Shenanigan13
May 28, 2010 09:30 AM
mines hotter
10
Aug 1, 2009 01:16 PM
cwebb
Jun 26, 2003 07:46 PM
