Bent Crankshaft - Would this cause any problems??
Old Apr 2, 2013 | 01:03 PM
TURBO_S2K's Avatar
We purchased a used crankshaft for a friend
We checked it for straightness and looks like there is a 5 degree bend on the tip where we install the crankshaft pulley
Can we use this crank? Would it cause us any problems?
Here is where the bend is:
Old Apr 2, 2013 | 01:15 PM
Evo Inferno's Avatar
From extreme vibration to destroyed bearings and journals. That needs to be straight.
Old Apr 2, 2013 | 01:55 PM
satan's rx7's Avatar
That seems like it will be way too far out of spec and like Inferno said will put a ton of strain on everything that mates with the rotating assembly.
Old Apr 2, 2013 | 01:57 PM
mdsevo06's Avatar
How did you measure it?
Old Apr 2, 2013 | 02:17 PM
todd6027's Avatar
x2
Old Apr 2, 2013 | 02:28 PM
TURBO_S2K's Avatar
with this:
Old Apr 2, 2013 | 08:24 PM
blowngasket's Avatar
Ah the Old Komparator Ve Sehpasi,
Is the bend at the ends or was this a total measurement? Whats the difference in the mains?
Did you have it magnafluxed for crackes to? Thats just to much out of spec Either way it was measured, that thing would vibrate.
You measured it in the block with the mains torques down?
Old Apr 3, 2013 | 03:15 PM
todd6027's Avatar
Originally Posted by TURBO_S2K
with this:
torqued down in place ??
Old Apr 3, 2013 | 03:33 PM
joseph143's Avatar
Have a machine shop recheck it... If it really is bad it will trash your motor in hours if not minutes... As the high side passes over a bearing it will squeeze all the oil out of the way causing galling and probably spin the bearings... Then your block will join it in the trash...
At best you can shave it back to spec but then dont plane to run more then 25psi... The load will crack the journals
anthonypazsd
135
Apr 2, 2026 12:56 PM
Paulevo9
Mar 21, 2016 09:34 AM
Mikey65529
Oct 12, 2015 03:20 PM
clanzkiller
Apr 16, 2013 11:25 PM
jrsimon27
Lancer Engine Tech
Mar 24, 2011 12:26 AM
