Blow off valve making high pitch whistling
Old Apr 2, 2013 | 01:48 PM
R. Burgundy's Avatar
I have a greddy type s that came installed on my car (hate it). When I'm cruising at highway speeds and the throttle is at like 10-15% (like pretty low), I get this annoying whistle coming from my blow off valve. The tone changes based on my throttle position. When I'm off the throttle, it goes away. When I get passed that certain point, it goes away...but I'm concerned its not set up properly.
Should I just try adjusting it "harder"? I was never really sure how adjusting these worked...
Before some one says it...yes, I know I should get a 9 bov.
Old Apr 2, 2013 | 02:53 PM
kanovic's Avatar
Mine used to do that and the prob was the spring was all rusted so it wouldn't squeak and whistle.. Is it holding boost?
Old Apr 2, 2013 | 06:48 PM
It seems to be holding boost fine
Old Apr 2, 2013 | 07:35 PM
90zcrex's Avatar
Mine did the same thing, I adjusted it a bit tighter and it almost went away, still a little bit sometimes but not nearly as much.
Old Apr 2, 2013 | 08:01 PM
hiboost2.0's Avatar
What your boost gauge when it happens. Is it around 0?
Old Apr 2, 2013 | 09:08 PM
S_manRR9's Avatar
Having the same exact problem with an OG synapse BOV, could it just be the adjustment?
Old Apr 2, 2013 | 10:08 PM
djdnav's Avatar
Greddy valves are notorious for leaking.. Cranking down the spring tension may fix that but then it may cause surging
Old Apr 3, 2013 | 08:54 AM
I'll give it a try, can't hurt i guess. I really dislike pretty much everything about this blow off valve hahaha...
Would a retune be completely necessary if i swapped out my bov for a different one? Obviously decremented, but would it hurt if i didn't?
Yea 0 or a little bit below.
Temujin
Apr 20, 2016 05:05 AM
Patrrrick
Sep 9, 2013 09:36 PM
Blue_05EVO
Feb 5, 2012 01:52 PM
dudical26
15
Aug 26, 2007 04:32 PM
EVOBrad
Oct 2, 2006 07:15 AM
