Oil Leak-Oil found in Intake Manifold...Help
Lol, yeah guess Im just making excuses. I'll get to it sometime...
Thanks for your help! I should just fly you out to MA and have you take care of it since Im so incompetent haha
That's a really cool space you have there! I'll have to PM you and pick your brain about that gantry crane setup you have over the lift as Im hoping to do a similar thing. Looks like your shop is similar to my space I've got a 32x24 gambrel with a 2nd floor for storage. But don't want to continue to derail this thread as its been going strong for a few years with a lot of helpful tips and places to investigate pesky oil leaks.
Lol coming from the captain himself
I think I may have to stop responding to your countless newb emails...This is a Mitsubishi enthusiasts site; don't you have a Miata or Mini or something to work on haha!
When I did my clutch the rear main wasn't leaking at all so that could be ruled out. On the front main, there was a tiny bit of oil mist on the block around where the oil pan met, but it definitely didn't look like enough to be the path that was covering the back of the block
I swear ours must be leaking in the same exact spot. I had no oil near my clutch so in my case too its gotta be coming from the passenger side then.
As letsgetthisdone stated
Was there ever a definitive conclusion to the most likely leak paths? I’ve got the subframe and driveline out and would love to seal up the source of my ‘slick.
For those who’ve added significant crankcase venting, did that measurably improve the leaks?
Sadly no I never figured this out prior to killing my motor a few months ago. I think I had a few issues that were't exactly tied together but essentially made me think something was amiss and related when reality everything was mutually exclusive.
The one thing that I never tackled was resealing my oil pan and it was certainly plausible thats where my leak was coming. But I never confirmed that.
As far as oil in the IM when I last pulled it off there was still some oil in there and this was after I addressed CC pressure issues and opened up the side vent.
After disassembling my head I found that I trashed a bunch of valve stem seals. So another theory was that oil was slipping past them and found its way into my intake manifold.
Where is youu mess? Internal or external? Apparently oil can creep so if you've addressed all the misc gaskets and sensors that could seep and you havent looked into your oil pan might be worth investigating further.
The firewall side of the block is all slick. There doesn't appear to be a single source, and it starts along the bottom of the intake manifold and gets worse on down, biased toward the front. Tranny is out and the rear main is fine. I've sealed the pan before, but will again as soon as I get the modified sump back from repairs. There is a single drop dangling from the knock sensor presently...
Planning to clean it all up again, then thread seal the oil pressure and knock sensors. Yes, I know the knock sensor hole is blind. Also planning to do TSComp Tom's valve cover fitting mod. Hoping the internal pressure is what's pushing out the oil.
Heliart
15
Oct 2, 2023 02:33 AM
Tougefreak
Nov 13, 2017 02:45 PM
FS[Mid-Atlantic]: MD: 2004 Mitsubishi Lancer Evolution VIII SSL Apex Silver - 125kmi BBK Full $14,000
ghammer2
For Sale - Cars For Sale
Aug 8, 2017 11:46 AM
Tougefreak
May 25, 2017 06:20 PM
Fstyles05EB
Jan 31, 2017 04:39 AM
