Evo IX Cams
Old Apr 10, 2013 | 05:51 PM
benIX's Avatar
Evo IX Cams
Hello Evo M. i was looking into getting cams for my Evo IX SE. after doing some research i saw some threads about MIVEC cams snapping at the pulley and messing up the whole internal of the engine. now my question is how many people actually had that problem and is it worth the risk to put in after market cams? i am not looking for crazy HP i would be happy with 350-400 HP but i'm not sure if ill achieve that goal without cams. and do i need to change the springs/retainers and get ARP head studs for that much power?
you guys-es help would be greatly appreciate it.
thank you in advance
Old Apr 10, 2013 | 06:46 PM
9evolution's Avatar
You dont need cams to achieve those hp goals, tbe,3port,intake,licp, tune you will get 320-350 whp.
Cams will not help much unless you upgrade the turbo. If you go turbo and cams i would do springs retainers and head studs.
Old Apr 10, 2013 | 06:51 PM
spinner85's Avatar
Not so sure you can reach your goal on stock cams. Agressive as the MIVEC cams may be. Maybe the 325-350, but if you want to go 375-400 you'll need cams.
Any cam has a chance of snapping. I have a set of GSC S2 cams with GSC beehive springs and retainers waiting to go in mt IX. You only need to replace the springs if you have really agressive cams or plan on revving passed the stock rev limiter.
I have a similar goal in mind but am not installing ARP head studs. There are several members on here daily driving on 450+whp with stock studs with no issues.
Main thing you should worry about with that power is the drivetrain. i.e clutch, lsd and t-case. depending on how hard you plan on driving, and whether or not you want to track or drag your car.
Good luck
Old Apr 10, 2013 | 06:56 PM
9evolution's Avatar
^ i dont think the cams will help much without a bigger turbo. Expense vs results i dont think its worth it. . If the head is going to be apart to install cams, might as well do the studs. There not very expensive imo. Im at 340hp on a mustang dyno,
Old Apr 10, 2013 | 06:58 PM
silverofs's Avatar
I made about 500 whp without cams in my Ix pretty simple setup with a t3 6262. Stock studs ect..
Old Apr 10, 2013 | 07:02 PM
9evolution's Avatar
https://www.evolutionm.net/forums/ev...-cam-test.html
Old Apr 10, 2013 | 07:11 PM
spinner85's Avatar
I can throw links around too
There are a bunch of different routes to get the power gains you want. Just depends on what you want done to your vehicle.
Old Apr 10, 2013 | 09:40 PM
Jax419's Avatar
I have GSC S1's on my car with stock turbo, stock motor on e85 @29psi and other supporting mods
Haven't had any problems with it snapping, the car made 421/382
Old Apr 11, 2013 | 02:52 AM
benIX's Avatar
Thanks everyone for the input. I have all the supporting mods. I did buy bigger injectors but haven't put them in yet. Not even sure if I do need the bigger injectors if I'm not upgrading the turbo. I do want to try to go E85 on stock turbo. I have RC 1200cc which I got from another member.
Old Apr 11, 2013 | 03:26 AM
joseph143's Avatar
To the 6262 guy, of course putting a big turbo on a car will net big power.... Some people like to use their power band...
A turbo upgrade is not required to see good gains on a simple setup with cams... I ran the stock turbo to 400hp on meth...
Also to the OP its uncommon for cams to snap, and some companies havent had a set fail, or claim not to. If you wanna play it on the safe side get a used set of cams. If it didnt break when the first guy had em chances are they wont on you. Especially if it was in a build motor, i ran my fp4rs without issue on 2 different setups... With and without springs... On 3 different turbos... And can honestly say they are damn good cam's... 596whp isn't anything to shake a stick at...
Old Apr 11, 2013 | 03:28 AM
joseph143's Avatar
Ps... The ams cam test was done on an evo 8... Will idiots with evo 9s realize it doesnt mean crap to us and stop referencing it already...
Old Apr 11, 2013 | 05:37 AM
9evolution's Avatar
I was just giving the op some reading material that covered cams. Your link was a good read, im still not convinced that cams without larger turbo are worth the dollar to power ratio.
Old Apr 11, 2013 | 08:56 AM
Shiroi Kitsune's Avatar
I'm in that range without half of that. TBE, MBC, and tune. I would expect with the added mods listed you would definatly be in the northern region of that. So cams for 350? Probably not. 400? depends on your goals and the route you take.
Old Apr 11, 2013 | 09:40 AM
Jax419's Avatar
Yeah you will definitely need bigger Injectors to run e85, even on stock turbo, the 1200's should be good, I'm running FIC 1250's
Old Apr 11, 2013 | 01:39 PM
9evolution's Avatar
My number seem low but its the dyno, virtual mustang dyno im at 400 whp, virtual dynojet im even higher, heartbreaking mustang dyno sits me at 340? Who know which one is more accurate.
al dopa
Lancer Engine Tech
158
Feb 24, 2026 12:37 AM
Ev1LEv0
61
Aug 15, 2011 04:04 PM
itsu
16
Jun 4, 2011 01:16 PM
Svendiesel
14
Jan 27, 2010 07:50 PM
2k4EvoVIII
Feb 12, 2004 02:26 PM
