4g64 Block Power Steering Brackets
Old Apr 15, 2013 | 07:31 PM
buford's Avatar
Hey guys. I have searched for some information on what to do with my power steering pump bracket for my 4g64 build and havent came up with much. The Evo bracket will not line up right. What are the 4g64 guys doing about this. Using 4g64 bracket? Will it work? Do I have to make a custom bracket? Any info would be appreciated. Thanks in advance.
Old Apr 16, 2013 | 04:18 PM
buford's Avatar
Anyone?
Old Apr 17, 2013 | 05:42 AM
evolve_VIII's Avatar
Im searching for the same information. If you find it, please post in my thead.
https://www.evolutionm.net/forums/ev...evo-8-9-a.html
Old Apr 17, 2013 | 06:35 AM
batty200's Avatar
I have a 4G64 and I will look at the brackets on Sunday if you still need the info. I Hahahaace both what was in the EVO functioning and the stock 64 brackets. I didn't assemble my engine originally so I never took notice that it didn't use the stock stuff.
Old Apr 22, 2013 | 08:12 AM
buford's Avatar
Did you ever get a chance tolook at the bracket?
Old Apr 22, 2013 | 09:53 AM
ExViTermini's Avatar
I just bolted up my stock accessory brackets last nite. They fit fine.
From what year/make/model is your block? Do you have a picture of the non-fitment?
Old Apr 22, 2013 | 12:22 PM
buford's Avatar
I dont have a picture at the moment. The two long bolts that bolt in on the front of the block fit fine. The two short ones that bolt in through the side are not lined up. The block is from a galant. Not sure the year. It was an 8th gen.
Old Apr 22, 2013 | 12:31 PM
galantman03's Avatar
I have a galant, and my build is using all evo 8 timing compenents and power steering pump, bracket and all. Trust me it bolts right up. The only thing that doesn't line up is the timing cover itself, for the power steering bracket cutouts
Old Apr 22, 2013 | 01:09 PM
What mount bracket are you using?
Old Apr 22, 2013 | 04:26 PM
buford's Avatar
I'm using the bracket off of my evo. Only 2 bolts line up.
Old Apr 22, 2013 | 04:45 PM
04slowevo's Avatar
Stock brackets for me on my 2.4L.
Old Apr 22, 2013 | 05:07 PM
Honto's Avatar
Stock brackets for me also on the 2.4, if you take a picture of how it's wrong I could probably post a pic on how it should be.
Old Apr 22, 2013 | 07:23 PM
buford's Avatar
Ok I will try to take some pictures when I get off of work in the morning. Thanks guys.
Old Apr 23, 2013 | 04:03 AM
buford's Avatar
No pictures needed guys. It turns out I wasn't using the evo bracket. It must be a 4g64 bracket. I found the evo bracket and it fits perfect. Thank you guys for yalls help. It was my mess up. Sorry. Had a noob moment I guess.
Old Apr 23, 2013 | 04:58 AM
Happens to the best if us, glad it's resolved!
darkmitsu
Lancer Engine Tech
282
Feb 27, 2024 01:31 PM
turbotsi
Lancer Engine Tech
Feb 4, 2013 06:08 PM
Alchem1st
14
Sep 20, 2011 04:27 PM
bvasquez12
Lancer Engine Tech
46
Aug 14, 2010 09:46 AM
01sleeper
Feb 15, 2006 07:44 PM
