Cam install prep ?
Old Apr 18, 2013 | 09:06 AM
kaonashi's Avatar
Cam install prep ?
So I just have a question as to what type of lube/ oil do you put on the cams when installing. I've always just put the oil on the lobes and never had any issue's but I was told I needed to use something else...?
Old Apr 18, 2013 | 10:24 AM
sktng22's Avatar
assembly lube. lucas makes it amsoil makes it..pretty much everyone makes it and you can get it at the local auto store
Old Apr 18, 2013 | 10:26 AM
Travis@GSC's Avatar
just about any type of assembly lube, it is a good bit thicker than regular oil and will stay on the lobes better while you finish assembly of the valve cover. Be sure to keep the idle around 2500 rpm for the first 15-20 min to keep oil pressure up and heat up the oil. If you have a leak it is ok to shut down the motor, just dont let it idle during the first heat cycle.
Old Apr 19, 2013 | 12:09 PM
galantman03's Avatar
also bleed your lifters.
Old Apr 19, 2013 | 02:54 PM
WRC-LVR's Avatar
IIRC STP also makes a good assembly prep. That stuff sticks to anything and is very viscous
Old Apr 22, 2013 | 11:44 AM
MechTech's Avatar
+1 on assembly lube
Old Apr 22, 2013 | 05:54 PM
bighead87's Avatar
how do you bleed lifters just wondering im going into the same thing with kelfords on sat
Old Apr 22, 2013 | 08:54 PM
sktng22's Avatar
https://www.evolutionm.net/forums/ev...r-lifters.html
evoniners
Jun 10, 2016 09:58 AM
evoniners
Apr 28, 2016 07:42 AM
Frew
Aug 5, 2013 08:02 PM
DrDeC
Apr 6, 2012 07:19 PM
magyar86
11
Dec 30, 2010 08:48 PM
