Help!!
Old Apr 18, 2013 | 12:04 PM
Vmoreno626's Avatar
Help!!
I'm new to these forums so bare with me lol I just recently bought a 2004 evo 8 with 78500 mile on it. Everything is great on it mechanically except my clutch / shifter. After sitting over night it is almost impossible to get into any gears ESPEACALLY reverse. I let it warm up for 5-10 mins and it still dsnt do anything. Once I finally get it going its good and bad It'll shift like it's brand-new when it wants to do and then it won't go in to gear sometimes and I'm not trying to force and after the car sits and I go back its either ****ty again or shifts like butter but reverse is never better it always fights and dosent want to go in and when it does it stays in for a sec then grinds and pops out. The guy said he had a stage 2 clutch in it and the pedal is real firm and catches real low idk if that helps. Any advice would be helpful thank you
Old Apr 18, 2013 | 12:11 PM
Travis@GSC's Avatar
Sounds like your clutch is not disengaging all the way.
you need to check for leaks in the hydraulic system for the clutch, and bleed the clutch.
If all of that is good, you need to remove the clutch and check the disc thickness. A worn disc will cause this problem also.
Hope this helps
Old Apr 18, 2013 | 12:21 PM
gsrboi80's Avatar
May want to try adjusting it out a bit. Especially since you are saying it's grabbing off the floor
Old Apr 18, 2013 | 12:50 PM
Vmoreno626's Avatar
Thank you to both of you it helps I'm deffinatly gunna take both your advice!
Old Apr 18, 2013 | 02:30 PM
intj123's Avatar
I had a stage 2 and it was just a crappy azz spec clutch the problem never went away until the clutch went away.
Old Apr 18, 2013 | 08:57 PM
Vmoreno626's Avatar
@gsrboi80 you were right the clutch pedal just needed to be adjusted thanks a lot!!
tsidrift1
39
Feb 4, 2014 05:15 AM
jmsrt4
23
Jan 30, 2014 02:10 PM
gsteensland
Aug 19, 2013 09:41 AM
yesevo
24
Feb 28, 2013 04:05 AM
RawrImAMonster
20
Jan 4, 2013 09:24 AM
