2.4 blown head gasket question
Old Apr 30, 2013 | 12:42 PM
evoboy2006's Avatar
I currently blew my head gasket on my 2.4 due to over boosting I was wondering if I need to get my head resurfaced before i put new head gasket on? I'm currently running h11 studs. Thanks for input.
Old Apr 30, 2013 | 08:27 PM
MaxStreets's Avatar
sorry to hear that, which gasket did u use 63 or 64 and brand.
Old Apr 30, 2013 | 08:32 PM
nismo05's Avatar
If you didn't resurface the head the first time, you definitely should this time.
Old Apr 30, 2013 | 09:39 PM
BEKevo's Avatar
How about you pull the head and check/ gauge for flatness ? It doesn't matter if you did it the first, second or third. You have to check each time, or have a machine shop measure the variance. If its flat and within spec, you can go ahead. Sometimes you can get away a couple times and still be within spec for flatness.
Old Apr 30, 2013 | 09:46 PM
joseph143's Avatar
for a blown head gasket i agree with bekevo... normal use and you pull things apart for whatever reason... definitely not necessary on a cast iron block... the head is a different story... if you lay it on a washer that you didnt notice and it sat like that for a 1hr day week doesnt matter.. check it...
Old May 1, 2013 | 06:05 AM
evoboy2006's Avatar
I was using a cometic head gasket going with cosworth now.
Old May 1, 2013 | 06:15 AM
Sharkbite2000's Avatar
If I was you I would check the deck make sure she's straight and your might as well do a quick refresh on the head just incase.
Old May 1, 2013 | 06:53 AM
evoboy2006's Avatar
I'm just pissed because the motor has 1000 miles on it fully built had all this machine work done now I gotta do it again lol
2006GSR
18
Nov 28, 2016 07:29 AM
boostawd16
May 21, 2015 05:58 AM
howell
13
Jun 20, 2014 04:08 PM
ezz-e
30
Sep 2, 2012 12:06 AM
FL_SilverEvo8
30
Mar 31, 2012 04:22 PM
