Small engine oil leak, unknown origin. Pic inside
Old Jun 8, 2013 | 01:50 PM
Raptord's Avatar
Pulled out of the garage a few days ago and noticed a very small spot of oil on the floor. Not enough for it to be a puddle, just a spot. Wiped it up, checked the next day, and there was nothing, so I forgot about it.
Today I back my car out again and notice another spot of oil at the same place. I jacked up the car to see what I could find. A plate (clutch inspection plate?) had a small film of oil on it, and oil was pooling on one of the bolts and dripping from there. I imagine the leak originates higher up than the plate as the whole thing had oil on it. See image below.
Anyone have any ideas where the leak could be coming from?
Old Jun 8, 2013 | 01:57 PM
Fast_Freddie's Avatar
Veteran: Navy
I say oil pan since it directly above it...
Old Jun 8, 2013 | 09:59 PM
Craig King's Avatar
If it's any correlation to you, my car was also displaying similar symptoms and I'm replacing the oil pan. $123 from Mitsu parts.
Old Jun 9, 2013 | 08:31 AM
WRC-LVR's Avatar
Remove the plate to see. If not the oil pan then it may be the rear main seal...Any issue with the clutch lately ?
Old Jun 9, 2013 | 12:09 PM
ReaperX's Avatar
I would lean towards the rear main seal.
Old Jun 9, 2013 | 04:35 PM
evoyrrah's Avatar
rear main
Old Jun 9, 2013 | 06:07 PM
ExViTermini's Avatar
Could be either rear main or oil pan, my vote is for oil pan as well. No need to replace it, just remove it and reseal it. Most oil leaks I feel can be attributed to crankcase pressure. The two little ports on the VC aren't sufficient at higher power levels.
Old Jun 9, 2013 | 07:47 PM
Raptord's Avatar
Thanks guys, will check oil pan later this week since it does't seem too difficult to remove.
Haven't had any clutch issues.
Old Sep 30, 2013 | 11:19 AM
mx4life85's Avatar
Any updates on this? Having a similar issue and would like to know what resolved it..
Old Sep 30, 2013 | 12:08 PM
Raptord's Avatar
Leaked stopped on its own so I never ended up investigating further. Had the clutch replaced two weeks ago and the shop didn't mention any odd leaks around that area.
Old Sep 30, 2013 | 05:41 PM
barneyb's Avatar
Spilled oil and gravity.
Ralliartize It
16
Jul 30, 2014 09:36 PM
CaTaSTrophiK
Aug 21, 2013 04:24 PM
turbotaloon95
May 30, 2012 06:04 AM
211Ratsbud
19
Aug 16, 2011 08:52 PM
88crxvtec
Apr 24, 2009 05:15 AM
