GTX30 comp wheel into GT30
Old Jun 11, 2013 | 12:48 PM
2.3stroker's Avatar
thinking of buying this
http://shopping.kinugawaturbo.com/ki...mtrim56-1.aspx
fit into my Gt3076,machine the housing and chra and balance .......
any idea guys??
Old Jun 11, 2013 | 04:03 PM
spdracerut's Avatar
It's not an authenic wheel. You can tell by looking at the blades. This wheel is flank milled leaving a smooth blade surface. The Garrett wheels are point milled leaving lines.
When you start taking the CHRA apart, reliabilty becomes highly suspect. You're better off selling your turbo and buying a genuine Garrett turbo. Not to mention, wheel to housing clearances play a role in reliability and performance and who knows what some shop will use for the clearances.
Old Jun 11, 2013 | 11:35 PM
2.3stroker's Avatar
ok, good point
Old Jun 12, 2013 | 09:54 AM
94AWDcoupe's Avatar
there are plenty people on DSM forums bolting in billet wheels with no balancing and getting great results. this wheel looks like exact duplicate of garret blade wheel. cause it most likely is. all the wheels they make are copies of someones elses work.
if you have a gt3076 this wheel bolts right in with no machining.
Old Jun 12, 2013 | 10:46 AM
ineedboostman's Avatar
I have a kinugawa turbo with billet wheel and it has those lines in it.
Old Jun 13, 2013 | 04:05 AM
2.3stroker's Avatar
mine is 52trim, so machine is needed, but it will def gain a bit(i guess)
Old Jun 13, 2013 | 05:05 AM
supersal's Avatar
Hey Guys
not sure if you've seen this:
http://www.ebay.com/itm/NEW-Design-11-blades-Billet-Compressor-Wheel-Garrett-GT3076R-HKS-GT3037-/130823466546?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e75afae32#ht_2747wt_934
they sem to be the guys that make these wheels they also have complete Turbos with what they claim are genuine Garrett chra's
http://www.ebay.com/itm/GTX3582R-Dual-Ball-Bearing-Turbocharger-Billet-Compressor-Wheel-/130830293958?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1e7617dbc6#ht_2190wt_934
has anyone ever used one of these?
regards
Sal
Old Jun 13, 2013 | 08:03 AM
17pstockcar's Avatar
The gtx series of turbos are garrets newest turbo line up. The follow on from the gt series of turbd that have been very popular in in different forms
Old Jun 13, 2013 | 08:21 AM
spdracerut's Avatar
Originally Posted by supersal
Hey Guys
New Design 11 Blades Billet Compressor Wheel for Garrett GT3076R HKS GT3037 | eBay
GTX3582R Dual Ball Bearing turbocharger with Billet Compressor Wheel | eBay
regards
Sal
That first link, the compressor wheel is obviously not a Garrett. On the GTX3582, that's not a standard Garrett compressor housing type. And it appears a serial number of something is scratched out on the name plate? So who knows if the clearances are machined properly on that compressor housing. If anything happens, it certainly will not be warrantied.
In my opinion, you're better off buying from an authorized Garrett distributor. There are too many reliability and performance risks with these turbos where these companies are swapping out wheels, machining things themselves, etc. Who knows what tolerances they use and balance specifications, or if they do any balancing at all.
SpeedI2acerX
13
Nov 4, 2016 01:40 PM
badev0
Oct 21, 2015 06:09 AM
sgambino92
Mar 22, 2013 09:41 AM
boonkae
14
Apr 10, 2011 01:29 PM
joprout
Dec 19, 2009 08:01 PM
