Spark plug wont thread in.
Old Jul 13, 2013 | 01:13 PM
FinnMR's Avatar
Okay so I did a compression test, and when I tried screwing my spark plug back in it just wouldnt grab or tighten down just kept spinning. So I thought it might be the spark plug itself, but it screwed down just fine into one of the other cylinders.
I dont know what to call it but, are my threads stripped in the block?
Old Jul 13, 2013 | 02:36 PM
MyronGainz's Avatar
Sounds like you might have damaged the threads in the plug well. If that's the case, Don't try retapping it in the car, pull the head and get it done properly
Old Jul 13, 2013 | 05:40 PM
FinnMR's Avatar
thanks for the help Myron
Old Jul 13, 2013 | 08:06 PM
barneyb's Avatar
I've never had to deal with this problem but stripped spark plug threads in aluminum heads is a common problem - a problem certain automotive shops can fix. Check around.
Old Jul 14, 2013 | 02:35 PM
RSGuy's Avatar
any competent machine shop can fix that for you
Old Jul 16, 2013 | 08:43 AM
Teal2nnr's Avatar
Sucks you have to pull the head for something like that....but its the only way you can do it properly.
Evoguy!123
Jul 20, 2016 07:26 AM
icmanevo
Oct 3, 2012 02:36 AM
sanderson
Aug 10, 2009 02:58 PM
evilevo2003
Jan 5, 2009 03:09 PM
MVEOVA
Mar 9, 2005 07:28 AM
