clutch and flywheel torque specs???
Old Feb 23, 2004 | 11:28 AM
jesslo's Avatar
Please help me!!! I am installing a ACT stage 3 clutch and an alunminum flywheel. What are the torque specs for the flywheel to crank and pressure plate to flywheel. help quickly please I am starting the install in about 4 hours and don't feel like figuring out the old fshion way. thanx all jesse
Old Aug 27, 2004 | 09:33 PM
sr20det91's Avatar
Same here. I'm doing the clutch in the morning and have been trying to figure this same thing out all evening.
Bump
Old Aug 28, 2004 | 04:33 AM
marksae's Avatar
From the shop manual:
Flywheel to crankshaft bolts - 98 +/- 3 ft-lbs
Pressure plate to flywheel bolts - 13 +/-2 ft-lbs
Some tips:
I would use some red or green loctite on the flywheel bolts. You don't want those things backing out on you!
Also, you should tighten down the pressure plate to flywheel bolts in small increments and in a cross pattern just to make sure the pressure plate seats properly against the flywheel.
Good luck!
vmrevo9
15
Nov 20, 2010 09:03 PM
Dragracer187
Apr 3, 2010 01:58 PM
faraz
Jun 5, 2008 08:27 AM
Dem_z
Lancer Tranny/Drivetrain Tech
Jul 9, 2006 08:32 AM
AvatarOfWar
Sep 17, 2003 02:13 PM
