Evo IV ayc delete verification
Old Aug 9, 2013 | 06:08 PM
87vr6's Avatar
I have an evo IV with ayc, I have access to an evo IV rs, so from reading all I need is the diff, mustache bar, axles? How about the rest life getting rid of the ayc stuff and still having my abs work and such? Thanks guys
Old Aug 9, 2013 | 08:22 PM
94AWDcoupe's Avatar
I converted my evo 4. you will need the parts you listed plus the front mount . you abs wont work. need to remove abs bulb in dash. delete saves 49 lbs! I added rs tcase with limited slip, so there are three mechanical LSDs on board.
Old Aug 10, 2013 | 04:58 PM
87vr6's Avatar
The front Mount as in? Front mount of the rear diff? I'm wondering if I should pick up the transfer case from this guy too... is there any way to retain abs?
Old Aug 11, 2013 | 04:44 AM
stunt2's Avatar
wrong
I've converted mine and ABS still works normally
ayc won't work without abs but vice versa it's all ok. abs works without ayc
Old Aug 11, 2013 | 06:30 AM
94AWDcoupe's Avatar
my abs light came on after my conversion. didnt care as I planned abs removal anyway. abs is for kids. dead weight for me.
Old Aug 11, 2013 | 06:40 AM
87vr6's Avatar
Thanks for clearing that up stunt2. I think I'll grab that transfer case too since it's cheap enough
Old Aug 13, 2013 | 04:56 AM
87vr6's Avatar
Yea. Guy was trying to rip me. Went today to pick up the parts (rear diff, transfer case) saw two ports on the rear diff dripping hyd fluid... "Thought this was a RS diff?" "It is, that's where the lines hook up to the oil pump".... "Uhhh, the oil pump is for AYC, which RS' don't have..."
Walked away, money intact.
Old Aug 13, 2013 | 05:59 AM
211Ratsbud's Avatar
+1 for you
Ganabi
Nov 12, 2023 11:30 AM
dillons13
Apr 24, 2016 05:13 PM
JOSEVOIV
Oct 14, 2015 06:49 PM
RoryE4
Sep 21, 2015 05:40 PM
Ferp
Sep 15, 2015 08:52 AM
