FP Cast Race Manifold for the 4G63
Old Dec 20, 2013 | 06:43 AM
  #346
92 GSR-4's Avatar
I believe the "porting" option refers to the port work at the turbo collector. The runners are all port matched to match the exhaust manifold gasket and cylinder head ports. That's what I understand at least.
Old Dec 20, 2013 | 12:08 PM
  #347
92 GSR-4's Avatar
Just an update for anyone who gets the bolt kit along with their manifold. The bolt kit comes with 8 washers. I called FP to find out why and I was told that each bolt and the two nuts are supposed to have double-stacked washers underneath them.
Torque spec is OEM specs - 47 Ft-Lbs for both the bolts and nuts.
Hope this helps someone.
Old Dec 20, 2013 | 02:10 PM
  #348
mx4life85's Avatar
Thanks can't wait to install mine. Should have it by the 23rd
Old Dec 20, 2013 | 04:53 PM
  #349
JohnnyTSi's Avatar
This is obvious to us DSM owners, for those new to the Mitsubishi scene :
The washers are 'cupped' on one side and have 2 dots on the other, the washers should be installed stacked together with the cupped side facing each other and the dots out.
John-
Old Dec 20, 2013 | 05:05 PM
  #350
Frew's Avatar
What's the reasoning behind the washers? Please excuse me if I missed the answer in a previous post.
Old Dec 20, 2013 | 05:24 PM
  #351
Paul Walkin's Avatar
Originally Posted by golgo13
I like that it has threads for the OEM heat shield. Super stealth FTW!
QFT
Old Dec 20, 2013 | 06:54 PM
  #352
92 GSR-4's Avatar
John-
Absolutely right. After owning a DSM 11 years you would think I knew that - wrong.
To clear any confusion, the bottom washer goes dots-down and the top washer goes dots-up.
They create a "spring" in a sense. If you place them together like they are supposed to go, with the concave sides together, they create a shape kinda like this: ()
When the exhaust heats up, expands and starts putting stress on the bolts, the washers will act like a spring and keep the bolt from stretching.
Looking back on it this is probably the #1 reason people have turbo bolts loosen up on their own, or snap when you take a 20 yr. old 14B off a DSM. Haha.
Just a last note for everyone. My manifold had a little issue where I was unable to fit any kind of wrench or socket on either nut. I was going to use the old 6-point DSM nuts instead of the ARPs so that I could get an open-end wrench on it. I called FP to let them know, and after 3 conversations on the phone it was determined that some of the casts aren't "perfect" and the clearance to allow a tool to be used on the nuts was off a little.
I would have either had to just use one washer, or take a grinder to the manifold. Even using one washer, I was still unable to get a wrench on one of the nuts. Well, I wanted to do it right...
Problem Solved.
Manifold setup looks good.
Old Dec 20, 2013 | 07:38 PM
  #353
wreckleford's Avatar
That would kind of suck if you had it coated first and then had to grind it.
Old Dec 20, 2013 | 08:35 PM
  #354
211Ratsbud's Avatar
Secks.
Old Dec 21, 2013 | 02:45 AM
  #355
pupo's Avatar
Mine is on the way, it should be here by Monday, on the invoice it says 21 out of 20, so it looks like they sold more than 20 at the introduction price!
Old Dec 21, 2013 | 05:04 AM
  #356
Yogi_B's Avatar
A bit 'after the fact', but perhaps something like this may have worked, or maybe helpful for anyone else that comes across this problem:
http://buy1.snapon.com/catalog/item....roup_ID=682706
Old Dec 21, 2013 | 09:26 PM
  #357
lopillo_evo's Avatar
Veteran: Army
subscribe wanna see dyno numbers, so I can put one on my fp red
Old Dec 23, 2013 | 08:53 AM
  #358
06MREvo's Avatar
So since FP was informed of the fitment issue will they be grinding these down for us before shipping them out???
Man, I would be pissed if I paid FP to have my manifold coated before shipping & I received it and had to take a grinder to the manifold in those spots.
Old Dec 23, 2013 | 06:30 PM
  #359
evo8426's Avatar
Finally! One is ported and one is not.
Attached Thumbnails FP Cast Race Manifold for the 4G63-img_0726.jpg   FP Cast Race Manifold for the 4G63-img950300.jpg
Old Dec 23, 2013 | 07:03 PM
  #360
211Ratsbud's Avatar
What is the metallurgical composition of this piece? Is it cast stainless steel? Likely not cast iron is imagine
