FP Cast Race Manifold for the 4G63
The manifold material is irrelevant, if you're snapping bolts it's because the threads galled and ended up seizing. It's extremely common on bolts that are heat cycled a ton. You need to either use inconel hardware like the factory hardware, or use a good high temp anti seize. Loctite makes a few anti seizes that are good for 2500F.
Ya I purchased the longer (dsm) bolts. Haven’t ordered manifold just yet. But I was wondering from an aesthetic standpoint if I should go with the ti. But kind of worried about them snapping off.
It's a spray-on coating for the inside of headers. I used it on the inside and outside of my manifolds, the outside of the turbine housing, and brake calipers since it stands up to the heat. The stuff is awesome.
They also now make a darker, grey color that I really like, for a manifold.
wht95scort
Aug 6, 2018 01:21 PM
FS[South]: FP EVO 4-9 Race Manifold
Slow_Supra
Dec 29, 2016 05:00 AM
heyzeus11
28
Jul 6, 2010 12:31 AM
This is after two years of autox and track use. I gave my turbine housing the same treatment.
