FP Cast Race Manifold for the 4G63
The manifold isn't supposed to be gasket matched on the motor side since the head isn't matched with the gasket. On both the ported and nonported units they are identical on the head side, the only difference I could see was on the turbo side.
Im not sure if anyone has asked this question yet; but if you are going through the trouble to make your own performance cast manifold, why wouldnt you design the inlet and outlet ports in the manifold to be larger so that it wouldnt have to be ported? This seems very stupid to design a higher/better flowing manifold only to have it be sent out for porting for additional $$. THen you have to spend an additonal $50 to bolt it up to your stock turbo.... If you buy all the options it comes to $675.00.
...I will have Curt send it directly to my powder coater though.
it is hard to have anything cast in a way to be 100% perfect fit to another cast part, made by a different manufacturer..
In reality, what you want to do is NOT port the flanges following the gasket, but rather make a dummy gasket and cut the exact image of the flange on the head side, and do the same for the turbo.. then you just take it over to the exhaust manifold and you will see where to grind away to have the perfect fit between the two.
I'd say that for a reasonable ammount of money FP will sell you a cast piece that looks OE from the outside and has better runners... all you have to do is play a bit with the flanges to have the perfect fit..
If only the shipping wasn't more expensive than the manifold itself, I'd have one in a heartbeat..
With the pictures posted with the stock gasket, they could have opened it up quite a bit then you would only have to spend 20 minutes cleaning everything up.
My family is from Croatia. Next time we take a trip back I could bring one with me.
100 porting
100 coating
50 bolt kit
30 gaskets
plus shipping
680 total plus shipping
I understand that it will not be perfect port matching with cast parts. I used to work on the cast manifolds on the ecoboost v6 at ford in prototype. It was a PITA to get everything to work properly. At least align and flow with the turbos we were testing.
even without the manifold..
I just got the HTA71 last summer... it is still in the box waiting for it's turn.. I would have probably bought the manifold if I knew it was coming.. but I think I will run it with stock ported...
I'm from Croatia too lol
Is this somehow better?
