FP Cast Race Manifold for the 4G63
Anyone slap this in and dyno it yet?
I haven't put mine on yet. Waiting on a few more parts to arrive in a next coming months.
Theres a semi-local guy that I tune got one. Were are prob gonna arrange some testing, on the road with VD and on the Dynojet. We'll see what happens....
Just finished tuning Anthony's VIII with a ported FP Cast Exhaust Mani with a BBK Full on E85.
A couple days ago he just bolted on the mani and did a pull without changing the tune from our tune from June of last year. HP went up mid range but peaked at the same HP but TQ went up midrange too but peak was 20 lb/ft more. Some of this is due to weather, but the boost plot was the same.
I did adjust the tune with just the ex mani, but didn't spend too much time as he wanted to get his other parts on.
Fast forward to today and after bolting on a Rev 3 Map Intake mani/TB set up and fully tuned he's just over 500 HP and 440 TQ.
VD Plots:
Blue from June 3, 2013
Green from January 6, 2014 No change in tune with FP Exhaust Mani
Teal from January 7, 2014 Adjusted the tune with FP Exhaust Mani
Red from Janurary 11, 2014 Tuned with FP Exhaust Mani, Map Rev 3 Intake Mani/TB
VD Plots:
VD Plots:
Green from June 3, 2013
Blue from January 6, 2014 No change in tune with FP Exhaust Mani
VD Plots:
Also, should probably just plot the Green and the Teal. That best shows the change from the mani.
No time. I mainly do logs in the evening after work.
I was in a rush to get my car ready for an upcoming trackday.
I'm really happy with the car, 1st and 2nd spin with 275/35 tires
We will be dialing things back since I have a stock bottom end and I mainly road race instead of drag.
Thanks again Christian
And good idea on dialing it back for the track.
Here is a more recent pull from November 2013 (Gold Lines). The red lines are with the FP mani and no adjustment to the tune. It did cause leaner AFR's as well as @ 1-3 psi more boost.
The Green Lines is with one adjustment to the tune with the new ported FP exhaust mani. Again the gold lines are from November 2013 with the stock mani. Anthony wanted to get his other parts on and completely retune it so we didn't spend anymore time adjusting the tune.
do you have a pic of the head side with the gasket?
