Throttle hang issue at high RPMs
Old Oct 13, 2013 | 04:47 AM
LaurenBBY's Avatar
So recently, when I'm driving relatively fast and I shift, my RPMs stay where they're at and sometimes even rise before returning to where it should be. For example, if I'm in 2nd gear and I shift at 5500, the RPMs rise to a little over 6000 before dropping back to say 5000. From the time the risen RPMs drop to where they should be, it's almost like my car is in nuetral and I'm gaining no speed. I've been told it sounds like my clutch is slipping, but in the past I've had the issue where I tap on the gas and my RPMs shoot up to 8000 and the gas pedal gets stuck down and my car goes into neutral. Only way to fix it is to turn the car of and then back on and then it's fine. It's only happened a few times. So I have reason to believe the whole thing has something to do with my throttle cable. My mechanic told me that many people who put an evo 9 turbo in an evo 8 have this problem where the throttle body gets stuck open and he said putting a spring on it solves this problem. He's now changing his mind and saying it sounds like clutch slipping so I'm really not sure what's wrong or how to fix it. Any input would be greatly appreciated. Thank you.
-- Lauren
Old Oct 13, 2013 | 04:54 AM
st0mp860's Avatar
Does it happen in every gear?
Old Oct 13, 2013 | 05:04 AM
LaurenBBY's Avatar
Yep.
Old Oct 13, 2013 | 02:49 PM
McLaren F1 2003's Avatar
I had this same issue. There is an ECU hack to fix it.
Old Oct 14, 2013 | 12:17 AM
LaurenBBY's Avatar
So it has nothing to do with my clutch or throttle cable?
Old Oct 14, 2013 | 02:35 AM
Siluck2's Avatar
It's just an "evo" thing. Mine does it too, and it's annoying.
Old Oct 14, 2013 | 02:47 AM
sktng22's Avatar
sounds more like a toyota thing then an evo thing ive never had a problem like that
Old Oct 14, 2013 | 03:32 AM
LaurenBBY's Avatar
Just an evo thing? Meaning there is no solution? Because it's incredibly annoying when I take it to the track because I lose quite a bit of time and power every time I shift.
Old Oct 14, 2013 | 04:27 AM
Blitz's Avatar
There is a solution. Like Mclaren F1 2003 said, it's an ECU hack.
https://www.evolutionm.net/forums/ec...-evo-8-9s.html
Fixed my throttle hang right away.
Old Oct 14, 2013 | 04:56 AM
LaurenBBY's Avatar
Yes, but will this also fix the issue with my gas pedal getting stuck? Or is that unrelated?
Old Oct 14, 2013 | 05:08 AM
Sharkbite2000's Avatar
ECU programming should fix it , make sure you don't have any boost leaks also.
Old Oct 14, 2013 | 05:47 AM
LaurenBBY's Avatar
Okay thank you.
Old Oct 14, 2013 | 06:52 AM
mrfred's Avatar
check for boost/vacuum leaks.
Old Jul 11, 2016 | 10:55 AM
Evo_9ssl's Avatar
Helo
I have an evo9 that has some rpm problem, when im driving around 4500 to 5000rpm and i press the clutch in without presing the gas pedal my rpm shoot higher and sometimes goes to red line, only happinng on higher boost, normal driving is fine, any body had this problem before? Its not my driving forsure, my 03 evo8 didnt do it before,
Old Jul 11, 2016 | 10:57 AM
Evo_9ssl's Avatar
[QUOTE=Evo_9ssl;11638997]I have an evo9 that has some rpm problem, when im driving around 4500 to 5000rpm and i press the clutch in without presing the gas pedal my rpm shoot higher and sometimes goes to red line, only happinng on higher boost, normal driving is fine, any body had this problem before? Its not my driving forsure, my 03 evo8 didnt do it before, its hapening everytime i shift
