grinding noise ?? help..
Old Oct 20, 2013 | 08:18 AM
robin-evo6rs2's Avatar
Hello.
Just replacement a clucht on a VI.
Drove 170km fine.
Was going to map her today but every time I'm going over 20kmph a terrible grinding noise come from the front drive train.
When slowing down till 10kmph the noise stops.
Checked all the fluids all fine..
Help??
Old Oct 20, 2013 | 08:46 AM
JaYr_EvO9's Avatar
what kinda of clutch did you install
Old Oct 20, 2013 | 08:47 AM
JaYr_EvO9's Avatar
if you could get a video would help too
Old Oct 20, 2013 | 09:29 AM
Its a Helix organic
And youtube is checking it...... for the last hour!!
Old Oct 20, 2013 | 10:18 PM
After 6 hours Youtube gave the video clear
So what you think it is?
The road is smooth tarmac
The sound appeers to come from the front.
AYC is out to( lamp out off dash) code 82 and a wheelspeed sensor
Old Oct 21, 2013 | 10:17 AM
come on..
I need some options to test
Old Oct 21, 2013 | 11:08 AM
barneyb's Avatar
It doesn't sound like anything I've heard before. Also, I'm not familiar with the clutch used. Anyway, check the exhaust - make sure it isn't hitting something. Then check that the motor mounts are secure.
Old Oct 22, 2013 | 10:41 AM
Nebraskafandb's Avatar
If you just replaced the clutch and this started happening then its most likely clutch related. Does the noise stop when the clutch is engaged?
Old Oct 22, 2013 | 10:46 AM
Jackdlc's Avatar
Hey Robin,do u find out what it is..? was it the shaft bearing ? or is it something else ?
Old Oct 23, 2013 | 03:54 AM
The sound is not clutch related.
I can put the car in natural and the sound does not alter.
It have to be something with the drive shafts or diff/box.
As it is only speed related.
Old Oct 23, 2013 | 09:56 AM
flywheel is speed related, was it torqued down correctly?
Old Oct 23, 2013 | 10:04 AM
J_Striker's Avatar
If you have a wheel speed sensor issue, you could have false activation from the abs. If the computer is seeing one wheel traveling slower than the rest, it well activate abs to try to equal them out. It make a heck of a racket when that happens.
Old Oct 23, 2013 | 10:28 AM
Yes flywheel is torqed down.. accoording to the workshop manuel
132mn
At i should say the sound is road speed.. not engine speed related
I can, say put the car in neutral en rev it without altering the sound
@J_Striker
Your the 2e one with the same story
she got a wheel speed sensor fault.
21 fr right wheel speed sensor open or short circuit
I'm going to pull the fuse on the Abs and Ayc... That will shut them up
See it that helps
Old Oct 27, 2013 | 09:18 AM
Sound turned out to be a broken bearing in de aircon rad fan.
kevinmoua1
Jun 13, 2017 09:11 AM
EVOXTACY
Apr 16, 2017 04:30 PM
Dmx3alo
Apr 10, 2017 07:15 PM
YIfuEVO
Jan 26, 2017 06:44 AM
Kurt
Lancer Engine Tech
20
May 22, 2006 05:10 AM
