Rear Differential Problems, Help!!
Old Nov 18, 2013 | 03:31 PM
bomunari's Avatar
Hey Team,
Just want to firstly say thanks to people who have commented on my posts, you have all provided so much help and the feedback on here which is great. I hope to get to a point where im just reading posts instead of posting issues that day will come!
ok so... only had the car for 3 months.
I have 2 issues:
I have a cusco rear, centre and front... (im assuming they are 1.5)
1. On gentle take off, i cant slip the clutch when turning... it starts slipping the differentials in a bad way.. i can hear it. then get a burning smell, so the only thing i can do is just apply a small amount of power, clutch back in and then coast. once im moving its completely fine. OR take off with the wheels facing forward.
2. Second issue, again on take off, i cant go up any inclines in the road. does the same thing.... gentle take off, starts slipping the diff... but not in a good way. Is this all a result of the wrong oil?
thanks
Beau
Old Nov 18, 2013 | 03:52 PM
meckert's Avatar
If you smell anything other the 80/90 weight, then its your clutch. The diffs arent your issue.
Old Nov 18, 2013 | 05:14 PM
bomunari's Avatar
yeah, its a brand new heavy duty excedy full face sport clutch...
just wouldnt expect it to slip.
and the smell does not smell like clutch at all, ive smelt alot of burning clutches, this smells very different, closer to a mechanical friction.
Has anyone had this issue?
Old Nov 18, 2013 | 05:15 PM
bomunari's Avatar
Can the diffs pre-load (turned steering wheel as well) be set much too high?
could this put too much stress on the clutch on take off causing it to spin?
Old Nov 19, 2013 | 11:32 AM
barneyb's Avatar
The wrong gear oil can cause all kinds of problems. I'd suggest you get with the LSD maker and find out what they recommend.
Evo10HKS
Aug 10, 2016 06:14 AM
heel2toe
30
Mar 15, 2016 12:54 PM
EvoDan2004
268
Dec 15, 2011 10:31 AM
rawkus
38
Sep 19, 2011 07:19 PM
mocohead
Nov 2, 2010 07:59 AM
