Engine Slow rev up, in and out of gear
Old Jan 8, 2014 | 06:08 PM
unihappytime's Avatar
Hi guys, I have an Evo 7, and when I rev up the engine in neutral, it seems quite slow. It gets slower as the RPM climbs, anything past 3k it seems to be slower.
this is relefect when doing a pull, from 2.5K, the car runs great until 3.5k where the rev rate starts to slow down.
I free reved an Evo 5, which is almost stock, stage 1 I guess, it reved more happily too redline.
Any suggestions on what to check? could it be plugs, ignition coil? or the restrictive stock outlet and down pipe?
Mods in sig
Old Jan 9, 2014 | 04:28 AM
Faisalm's Avatar
I would suggest doing a compression test. If the compression isn't normal then there lies your problem. If its normal then please give more info, i.e does it cut off at any point? Smoke? Etc..
abrar
Jan 25, 2016 11:15 PM
MaDD-Myke
Dec 5, 2013 01:54 PM
1.8t
Dec 30, 2011 08:15 AM
MRwanTon
12
Dec 30, 2010 03:35 PM
jbergmeier
Oct 14, 2005 11:55 AM
