Half Shaft Definition.
Old Jan 17, 2014 | 08:30 PM
hatesposers's Avatar
Could someone please define the term "Half Shaft" for me.
What all does it include?
Thank you.
Old Jan 17, 2014 | 08:53 PM
galantman03's Avatar
the half shaft for an evo are the shafts that you have to remove from the transmission to remove the t case. Basically on my 03 eclipse has a fwd transaxle, and the axles have stubs that install into the transmission, and mesh with the diff in the tranny.
On the evo, since you're transferring power to the rear via a t case, you have to have an easy way to disconnect the t case from the transmission. That is where the half shaft comes in. The long half shaft which you have to remove from the drivers side axle with a slide hammer goes thru the transmission and meshes with the tcase lsd. and protrudes out on the drivers side, for the axle to slide onto. I hope this makes since as I just totally lost what I was going to type out.............................. dang cold medicine
Old Jan 17, 2014 | 09:06 PM
What you are describing is the intermediate shaft, not the half shaft
Old Jan 17, 2014 | 09:10 PM
i have always called them the half shafts so thats news to me.
The only other thing I could think of that would be called that are axles. because 1 only takes up half of the cars width, but thats a little far out i think...
Old Jan 17, 2014 | 09:45 PM
Here's the problem....
If you walk into ANY parts store, or talk to ANY mechanic, and you talk about half shafts, they give you everything between the transmission (in our case transfer case) and the wheel.
Meaning (per side) both CV joints, the inner and outer stubs, and the CV intermediate shaft...
Half shafts are also called "CV axle shafts"
Google "What is a half shaft" and you will see what I mean.
I paid a member here for Both half shafts, and he only sent me only the two CV intermediate shafts.
Here's the first definition as pulled up from Google. It's also from Tom and Ray Magliozi AKA Click and Clack, The tappet brothers from car talk....
What is a "half shaft", and what makes it give out?
Barbara
TOM: The "half shaft" is what you get from the dealer when your car is still under warranty. Once the warranty expires, Barbara, you get the complete shaft.
RAY: We're kidding Barbara. Front wheel drive cars like your Tempo have two axles in the front. They run from the transaxle in the middle of the car to the right and left front wheels. These axles are called "half shafts," because each of them spans half the width of the car.
Old Jan 17, 2014 | 10:24 PM
LetsGetThisDone's Avatar
yea, I would say the "half shaft" is the cv axle assembly, or axle, or cv half shaft. The shaft the goes through the trans and into the tcase is an intermediate shaft. Just like the short shaft that can be removed from the passenger side of the tcase that drives the passenger side axle...
Old Jan 17, 2014 | 10:51 PM
joseph143's Avatar
i was always under the impression a half shaft was an old school cv axle... before they were redesigned to use cv joints and still used a u joint... i think they were mostly for trucks... its something i was told and just believed... but when someone calls cv axles half shafts i dont argue...
a quick google tells me jag's ran them in the rear axles aswell... who knew
and the detmaso pantera as well
Old Jan 17, 2014 | 11:21 PM
anything with independant suspension on a driven wheel uses a half shaft. It allows the suspension to articulate without changing the camber. The alternative is a "solid axle" which has no articulation in it.
It seems on this site that people call Half Shafts as "Axles".... and that's where the confusion lies, when Half Shaft is the correct terminology in the rest of the automotive industry...
Here's a link from Rock Auto with a picture, and "CV HALF SHAFT" listed.
adawang
Mar 13, 2017 10:20 PM
adawang
Feb 5, 2016 04:29 PM
DEA
Jun 16, 2015 04:10 PM
Johnr352
11
Oct 15, 2014 07:59 AM
CrunchyMilk
May 21, 2011 07:13 PM
