running rich??
Old Jan 30, 2014 | 10:19 AM
Tehjoser's Avatar
running rich??
well let me star of with i just got my car out then shop after a month of hastling with clutch warranties.
drove the car for 500miles then all of a sudden when i was spooling the turbo i lost power. felt like a missfire on multiple cylinders. took it into the schools shop ran the code reader gave me no codes besides a downstream o2 sensor. i tried driving it back home with my friend behind me and black smoke was coming out the tailpipe almost as if i was running a diesil.
still no codes popping up. next question is i replaced a resistor pack for the injectors a couple months ago. before it was repleaced one of the injectors stuck open changed the resistor and problem solved.
could that be an issue again????.
also when i lighlty touch the gas pedal it will go no problem until i reach about 3 rpm and 15 mph it starts sputtering?
anyone else have this issue?
Old Jan 30, 2014 | 10:27 AM
bsh's Avatar
bsh
Popped a hose?
Old Jan 30, 2014 | 10:30 AM
gsrboi80's Avatar
Sounds like a major boost leak to me
Old Jan 30, 2014 | 10:31 AM
mr evo7's Avatar
Check your maf sensor.. I had similar issues and it didnt show any fault code
Old Jan 30, 2014 | 10:34 AM
Tehjoser's Avatar
idk if it can be a boost leak. would my boost gauge not be reading anything if there was a leak?
Old Jan 30, 2014 | 10:36 AM
Tehjoser's Avatar
thats something i had in mind to check but a buddy of mine said it could be more of a fuel problem since it seems like its running to rich
gsrboi80's Avatar
With a leak you are describing you may not see anything on the gauge
Perform a proper boost leak test on the system and go from there
Old Jan 30, 2014 | 01:05 PM
Tehjoser's Avatar
well upon further inspection i found that one of the clamps was not tight enough and cause teh hose to seperate from the ic... releived thanks u all for your help
duranvw
Jul 18, 2012 09:32 PM
jordantii
May 20, 2012 07:22 PM
didalos
25
Apr 13, 2012 08:24 AM
Brsox10288
Oct 19, 2011 09:18 AM
wrxedout
Feb 29, 2008 04:59 PM
