Evo in gear but doesn't move
Old Oct 1, 2019 | 07:11 AM
Tang tus's Avatar
Originally Posted by rupp003
I was driving my 2003 Evo 8 to my friends shop to change my power steering pump. I was rolling to a stop light, it turned green and I accelerated. Something gave way and I stopped accelerating. I pulled over.
Previously I was driving on the highway at 65+ for an hour before getting off the exit.
Car goes into all gears.
When stationary, I put it into gear, let the clutch out and it doesn't move.
Each gear, let the clutch out and it does this:
1/2 gear make a slight grinding noise
3/4 gear makes a louder grinding/rattling noise
5/R are the loudest
Clutch is engaging and the slave cylinder can be seen moving
I haven't pulled the motor/trans/tcase yet and I am looking to see if anyone has had similar issues.
Thanks for the help everyone!
Have you found what the problem is Bc now my evo doing the same thing and I can’t drive it
Old Oct 1, 2019 | 09:04 AM
kikiturbo's Avatar
take the transfer box out and look at the input teeth on the transfer box.. my money is that those are stripped.. I have seen it happen on the X.
Old Oct 1, 2019 | 06:24 PM
barneyb's Avatar
The speedometer is driven off the final drive gear. If it runs the speedometer as in the case of OP, then every thing before that is working (clutch, transmission) so my guess would be broken center differential.
YIfuEVO
Jan 26, 2017 06:44 AM
P0411
Jul 15, 2015 11:48 AM
urnamehere
24
Sep 13, 2013 06:53 AM
RawrImAMonster
20
Jan 4, 2013 09:24 AM
pb91
Jun 8, 2011 02:44 PM
