Which tial wastegate i should use?
Old Mar 9, 2014 | 06:30 AM
Evopower88's Avatar
Hi guys,
Someone can help me, i tell me whats the difference between the tial 38mm vs 44mm?
Thanks
Old Mar 9, 2014 | 01:11 PM
Faisalm's Avatar
Search button is very helpful:
https://www.evolutionm.net/forums/ev...wastegate.html
Old Mar 10, 2014 | 07:59 AM
Evopower88's Avatar
Originally Posted by Faisalm
Thanks!
Im thinking run 35 psi with c16
Old Mar 10, 2014 | 11:30 AM
E9vtk's Avatar
Always used a 44 and never had any boost issues.
Old Mar 10, 2014 | 11:54 AM
Faisalm's Avatar
The 44mm is a better choice. Less of a hassle and some would argue "better" performance.
Old Mar 10, 2014 | 12:45 PM
Evopower88's Avatar
I read in other forum, and said that the 38mm is for high boost aplication? Im confused..
Old Mar 10, 2014 | 03:06 PM
RS200's Avatar
The less boost you run, the more that goes through the wastegate. Sure, if you're running 30+ psi, the wastegate isn't going to do much. That being said, I had a 44mm and liked it.
Old Mar 10, 2014 | 03:32 PM
E9vtk's Avatar
That's what they say, but I've never had a problem with high boost and a 44 also less chance of boost creep.
Old Mar 10, 2014 | 08:19 PM
Evopower88's Avatar
Thanks guy!
In my car i already have a tial f38 thinking change it with the 44mm but i dont know is necesary or not.
Old Mar 10, 2014 | 09:17 PM
Faisalm's Avatar
If you are not having any issues with your wastegate like surging etc... then I wouldn't swap it out only because you're going to have to get an adapter plate for the vband on the 44mm and a tbolt clamp for the 44m etc..
If there's nothing wrong with it, leave it alone.
Old Mar 11, 2014 | 07:14 AM
Evopower88's Avatar
Ok thanks, i will let it, i dont want to spend money isnt necessary
Old Mar 11, 2014 | 09:07 AM
99gst_racer's Avatar
The only issue you might have with your current gate is that it's common for the paper gasket to blow out where it's thin on the edges. A good solution for this is to run an SCE copper gasket (part number 4150).
But if you aren't having any issues with your current 38mm gate, then I agree with these other guys in that you should just let it be. A 38mm valve is definitely appropriately sized for the application though. If you ever decide to switch to a v-band gate for the sake of simplicity (or ability to clock), you could very well run the 38mm MSV. But I would recommend cutting off the 2-bolt flange and welding on the v-band flange instead of using one of the adapters.
Old Mar 11, 2014 | 05:52 PM
Evopower88's Avatar
Oh thanks for your opinion, i order new gasket today, i will change it. Why you recommend that? Will have problem if use the adapter?
I will run with this setup, maybe in a future will change the exhaust manifold with the turbo too.
Old Mar 12, 2014 | 08:47 AM
IMO, one of the prime reasons for ditching an F38 for a v-banded gate is to also ditch the gasket. So if I were doing that, the last thing I would want is use an adapter that maintains a gasket.
Old Mar 12, 2014 | 02:21 PM
Evopower88's Avatar
Yes thats true.
Thanks for the help
fouringEVO
Dec 29, 2014 12:00 PM
Nickolaus
Dec 28, 2011 07:51 AM
Evoleader88
12
Feb 20, 2010 10:30 PM
Motoxrider7
23
Jan 3, 2009 08:22 PM
