evo 9 turbo installation.
Old Apr 3, 2014 | 03:29 PM
Charlie-Y's Avatar
Anyone?.
Old Apr 4, 2014 | 07:44 AM
egis's Avatar
Don't know about ticking noise but smoke is probably from leaky oil return line gasket on the turbo turbo side.I had the same.I let the car idle and aimed flash light at that part of turbo where oil return line attached.I did it from underneath the car.and I saw oil seeping slowly. that was enough
to create smoke
Old Apr 4, 2014 | 01:47 PM
thedru13's Avatar
Get under the car while its running and make sure no oil is leaking. Did you clean everything when you bolted stuff back on? Where is the clickin noise coming from? Video the noise might help pin point where and why.
Old Apr 4, 2014 | 03:27 PM
slowsrt4:('s Avatar
smoke could also be from your greasy hands touching the turbo during install
Old Apr 5, 2014 | 12:10 PM
Charlie-Y's Avatar
to create smoke
no i did not cleaned the oil from the turbo prior to installation , i did considered that it may be the case but is not.
I checked under the car no oil seeping , however their is oil on top of the turbo.
Here is the pic showing the oil siting on the turbo. I've re-tighten the bolt but oil keeps showing up here.
Old Apr 5, 2014 | 03:01 PM
thedru13's Avatar
Did you replace the crush washers on the banjo bolt?
Old Apr 5, 2014 | 03:20 PM
Charlie-Y's Avatar
Yes i did . two copper washer , one on the top and one on the bottom.
I tried throwing rubber o-ring leaks worst.
anyone knows the torque spec?
Old Apr 5, 2014 | 03:36 PM
thedru13's Avatar
trying to remember.. Think its these
Oil banjo bolt: 20-25
Water banjo bolt: 25-36
Old Apr 5, 2014 | 06:11 PM
Charlie-Y's Avatar
Not sure , but the smoke seems to come from the clamp between the turbo housing.
not sure if thats normal
Old Apr 6, 2014 | 08:27 AM
thedru13's Avatar
Did you clock the turbo? Did you mess with that clamp at all?
Old Apr 6, 2014 | 09:37 AM
Charlie-Y's Avatar
Nope I did not fidget with it. This evo 9 turbo is built with a anti-surge housing.
Not that it matters . Smoke smell like burn oil , not exhaust fumes nor coolant.
Tail pipe smoke is normal.
Perhaps a bad build.
Old Apr 6, 2014 | 11:04 AM
thedru13's Avatar
Take your intake off and see if the wheel is hitting anything or making any sort of noise. Also check if there is any oil build up in there.
Old Apr 22, 2014 | 09:13 PM
Vrbigdish's Avatar
Ticking could be manifold or turbo gasket leak. Had that issue before. Id pull the dp elbow and see if there is any oil in the exhaust side
Old Apr 23, 2014 | 07:00 PM
Charlie-Y's Avatar
had not have the time to pull things apart , but i drive and check the oil level frequently.
if oil level drop probably a leak ect.
The smoke have subsided i assumed that maybe it was the oil that keeps the turbo from rusting.
mike_89
Aug 13, 2015 08:38 AM
evo1981
Apr 28, 2013 12:32 PM
youlost
Evo X How Tos / Installations
Jun 3, 2009 06:51 PM
Evo8uk
Nov 29, 2007 11:55 AM
laxhero2
Jul 12, 2007 04:15 AM
