EVO 8/9 Synchrotech Carbon Synchros
Old Nov 30, 2014 | 05:59 PM
  #376
NFSLancerRA's Avatar
Originally Posted by Synchrotech
The synchronizer acts as the brake for the gear. The carbon lining is more aggressive and stops the gear rotation faster than the brass ridges on OEM synchros, reducing shift grind at higher RPM. The type of MTF does affect how the transmission will shift and function. We have had the best results with Torco MTF or RTF.
No no, you are missing what I was getting at. Regardless of what brand of MTF you prefer, there are essentially two different types and five (or more) different grades of fluid. GL-4 and GL-5 seem to provide better protection and lubrication (than OEM GL-3), but they are "active" fluids, which means that they will eat brass. I misunderstood the benefit of using these synchros. I was hoping that these synchros were completely hard metal. I agree that they still offer a significant benefit, especially for those who are revving out their cars.
I am also not very well versed on the true benefit of using GL-4 or GL-5 over GL-3 for high HP and TQ applications, so forgive my potential ignorance. I wasn't trying to diss your product or anything. I merely misunderstood what was involved with these.
Old Nov 30, 2014 | 09:13 PM
  #377
EvoTurboTurk's Avatar
Originally Posted by NFSLancerRA
Strength is totally irrelevant. If you eliminate the soft metal pieces in the transmission, then there is nothing stopping you from running whichever MTF that you so choose (unless I am missing something). However, it looks like the "new" synchros are still brass pieces with carbon material pressed in. Is this true? I thought that the point of the carbon material was that it negated the requirement that the synchros be a soft metal. I must have misunderstood something along the way.
Im confused when you say strength is irrelevant, so your saying which ever rebuild kit I get they are all the same?
Old Dec 1, 2014 | 05:05 AM
  #378
foxbear2277's Avatar
Any updates on this product from the transmission shops?
Did TRE and Shep get a set?
Old Dec 1, 2014 | 05:39 AM
  #379
No, certainly not. As SynchroTech said, these will do a better job of synchronizing shaft speeds in the transmission between shifts. Those who rev out their motors, now, will see a huge benefit from this. Strength is irrelevant in that these will not directly increase the overall power/torque capacity of the transmission (if I understand what is going on, and I hope that I do, as I am new to transmissions).
Old Dec 1, 2014 | 06:24 AM
  #380
Uh right I get you now, thanks 👍
Old Dec 1, 2014 | 08:01 AM
  #381
Synchrotech's Avatar
Still waiting for updates. Synchros sets were sent to Jacks, Shep, TRE and English Racing along with about 10 others that pre ordered from the first batch.
Old Dec 1, 2014 | 08:19 AM
  #382
powerdriver's Avatar
I'm waiting on a few things on my car before I send the trans out to TRE to have the carbon synchros installed.
Old Dec 1, 2014 | 10:14 AM
  #383
mrfred's Avatar
Drove a fresh trans with a set on Saturday. Was a brief drive, so I can't say much except that they work. Owner may have comment soon.
Old Dec 1, 2014 | 10:36 AM
  #384
What are the break in procedures for new synchros? I know when my trans is going in it'll have a new clutch, JDM 5th and a 4.08FD.
Easy shifting for a 1,000 or so miles, and then it takes roughly 5k miles for the synchros to break in before shifting feels "normal"?
Old Dec 1, 2014 | 02:49 PM
  #385
We suggest the same as a new clutch. Go easy for the first 500-1000 miles then have fun!
Old Dec 1, 2014 | 10:35 PM
  #386
McDougal's Avatar
My car is at English getting a rebuild with this kit. I should have it back by the end of the week and will report back when I do.
Old Dec 2, 2014 | 03:37 AM
  #387
Lexus01IS's Avatar
How will I find out when I will be getting my set and payment info.
  #388
-Make-'s Avatar
Hi!
Car is Evo5RS. What oil should i use with these carbon synchros?
I have Ralliart limited slip diff, so i have to use friction modifier with gear oil (Castrol Syntrans Transaxle 75W-90), will this work?
Old Dec 2, 2014 | 07:42 AM
  #389
We have added the EVO synchros to our site to make it easier for everyone to place their order. This offer will close in January 2015. Please click this link or use discount code EVOM for 20% off the synchros. You can also use the code for 20% off a Master rebuild kit, LSD or FD set. We have the EVO 4/5/6/7 synchros available but it will be a few weeks before more of the 8/9 synchros are finished. You can go ahead and place the order now and we will ship as soon as more parts are finished. http://www.shop.SYNCHROTECH-TRANSMIS...tm?coupon=EVOM
This image has been resized. Click this bar to view the full image. The original image is sized 900x598.
Old Dec 2, 2014 | 04:25 PM
  #390
Originally Posted by -Make-
Hi!
We normally use Torco MTF and friction modifier but if the Castrol MTF works well with the OEM EVO synchros, it should be fine with the carbon synchros too.
