EVO 8/9 Synchrotech Carbon Synchros
Old Apr 24, 2014 | 06:39 PM
  #106
lvtubasor's Avatar
ill love to take a set lmk please
Old Apr 25, 2014 | 06:40 PM
  #107
Sir2egk's Avatar
I'm in. And I can also do a write up with pics since I'll be doing it myself.
Old Apr 26, 2014 | 05:12 AM
  #108
supersnow's Avatar
6 speed please
Old Apr 26, 2014 | 09:54 AM
  #109
evolutme's Avatar
Offer it for the MR!!! I'll drop off my transmission tomorrow. Lmao
Old May 2, 2014 | 05:17 PM
  #110
WW-GSR's Avatar
I haven't done the research to see which cars use carbon synchro's (I'm curious to know which ones do), but the fact that majority of cars use & have used brass synchro's since synchro's have been around makes you ask why? Here are some thoughts I have on this: Why use a metal-based synchro? As the metal would wear, the particles because of their weight would naturally settle at the bottom. Carbon being as light as it is, would remain suspended in the gear oil as a result of its miniscule weight. I see 2 potential problems with this.
1. Carbon particles would end up in bearings "gumming up" (think: oil sludge).
2. Heated steel that is introduced to carbon causes hardening, which = brittleness. Not something you want from your gear teeth.
From what I've gathered you've been making these things for quite a while, but I couldn't help share some thoughts on this. Understand I'm not dissing on your product - just asking the hard honest questions. I, along with the other members I'm sure, would like to hear some clear responses to these questions. Not looking for a "we've been selling these XX years..they work."
Thanks.
Old May 2, 2014 | 05:55 PM
  #111
kaj's Avatar
kaj
Originally Posted by WW-GSR
the fact that majority of cars use & have used brass synchro's since synchro's have been around makes you ask why? Thanks.
because CF synchros weren't invented yet?
Old May 2, 2014 | 07:14 PM
  #112
mrfred's Avatar
The process of hardening steel with carbon is much more indepth than simply rubbing carbon against steel. What you are suggesting would never happen with carbon synchros rubbing against steel (the syncros do not rub the gears themselves) let alone due to carbon floating around in the oil. Besides, the gears are already hardened using carbon (and several other elements).
Old May 2, 2014 | 07:33 PM
  #113
WW-GSR's Avatar
Yes, brass synchro's came before carbon, but that wasn't my question. The question is which cars use carbon synchro's from the factory? I can't recall a single performance car that uses carbon synchro's. That's coming that way from auto manufacturers that invest millions into R&D. If carbon was that much more superior to brass, does logic not dictate we'd see them implemented on performance cars from the factory??
That's good to know. I'm still not entirely convinced of long-term durability (2-300K miles of use). Again, if they were that much more superior to brass, wouldn't we see them used more by manufacterers?
Old May 2, 2014 | 07:53 PM
  #114
BoredDSM's Avatar
From my personal experience some Civic SI's had 3rd gear issues where it would pop out. Honda released the bulletin and warranty extension on the vehicle to replace said synchros with carbon coated ones.
Also if you look at the synchrotech website you can see a pretty thorough explanation of how they chose to manufacture carbon coated synchros.
http://www.synchrotech-transmissions..._Synchros.html
Old May 3, 2014 | 03:37 PM
  #115
Synchrotech's Avatar
Carbon composite lined synchros have been used OEM in many models to improve shift performance.
Here are just a few::
Honda
Acura
Dodge SRT4
Audi O1E
Corvette T56
Mustang T5 world class
Old May 3, 2014 | 03:39 PM
  #116
Faisalm's Avatar
[QUOTE=Synchrotech;11198091]
Honda
Acura
Dodge SRT4
Audi O1E
Corvette T56
Any updates?
Old May 3, 2014 | 03:58 PM
  #117
We are still waiting for the engineering drawings and price quote for tooling. I should have an update in a week or so.
Old May 3, 2014 | 05:58 PM
  #118
kaj's Avatar
kaj
I have no doubt a CF synchro will last as long as brass under the conditions it takes to get 200-300k miles out of a trans without a rebuild.
Old May 4, 2014 | 03:40 PM
  #119
fallenauthority's Avatar
^^ Exactly
How many people are going to drive an evo for 200-300k miles without needing a rebuild regardless of what kind of synchros are in the trans.
Old May 4, 2014 | 04:07 PM
  #120
kaj's Avatar
kaj
Originally Posted by fallenauthority
^^ Exactly
one must have reasonable expectations. that's pretty high.
