Tranny issues
Old Apr 19, 2014 | 10:50 AM
josh_evo9's Avatar
Ok guys so today I disassembled the clutch assembly. Unfortunately it looks like it's had some abuse from the previous owner. I've only had it for two months and have honestly never launched it. But anyways can the pressure plate or middle plate be resurfaced?
Old Apr 19, 2014 | 12:01 PM
Faisalm's Avatar
I'm sure they can both be resurfaced. Alternatively, you can buy a whole rebuild kit for around $800 maybe less. The middle and pressure plate are around $150 each IIRC.
Old Apr 19, 2014 | 01:31 PM
josh_evo9's Avatar
Yeah, I've seen that you can buy the pieces seperately. I like the clutch, aside from the rough engagement and chatter. But that may have been from the TOB being on it's way out I'm not sure. But man $800 is a lot
Old Apr 19, 2014 | 06:18 PM
Faisalm's Avatar
Then resurface them and just buy the disks
Old May 6, 2014 | 01:47 PM
josh_evo9's Avatar
Ok, I ordered a new top plate, intermediate plate, and two new disks. Everything arrived and looks good except for the new top plate. My old one was dished on one side, and got thicker towards the middle. The new one is perfectly flat on both sides. Did I get the wrong part? Only reason I'm unsure is because the old plate looks like it was meant to be like that, it doesn't look like it's been worn down causing the dished surface
Old May 6, 2014 | 01:59 PM
Faisalm's Avatar
May you kindly post the part number for the top plate you purchased?
Old May 6, 2014 | 02:07 PM
josh_evo9's Avatar
PP02. I ordered it off of maperformance with the rebuild kit. But on the box for the top plate it has IM02 written on it. But I think that's the part number for the actual rebuild kit?
Old May 6, 2014 | 02:20 PM
Faisalm's Avatar
Yes, correct, you're good to go
As for the thickening part of your previous pressure plate, that could be due to wear. It should be flat from what I recall.
Old May 6, 2014 | 02:32 PM
josh_evo9's Avatar
Hmmm, I wonder if somehow the old plate may have been incorrect? Maybe that's why it tore some stuff up lol. I mean I won't disagree and say it's not like that from wear, but I'm almost positive it was machined that way. Also there's a groove in the old top plate that this small ring sets in. The new plate doesn't have a spot for that to ride on
Old May 7, 2014 | 05:03 PM
josh_evo9's Avatar
Here's a picture of my old pressure plate showing what I was talking about. It gradually gets thicker towards the inside of the plate then levels off. And where it levels off another piece sits in the groove. I'm stumped because the new pressure plate is completely flat. I called exedy and they were closed so I'll try back tomorrow. Don't wanna put it together if it's not right.
kyoo
23
Oct 29, 2017 09:32 AM
Babs
74
Aug 13, 2016 03:13 PM
Evo3573
12
Oct 8, 2012 06:18 PM
lowevo8
25
Sep 12, 2012 10:20 AM
Stew
27
Jan 22, 2012 09:42 AM
