How does the oem EVO 8/9 fuel tank work?
Old Apr 12, 2014 | 10:27 AM
2006GSR's Avatar
Stupid question.
What does all the sensors do on the oem fuel tanks!?
On the drivers side you have the fuel pump sending unit and what's on the passenger side?
Has a fuel lever thing and from what it looks lik.
Can any one explain to a newb
Thanks
Old Apr 12, 2014 | 10:44 AM
jrainwater's Avatar
There's a map sensor on there, not sure what it does. I always assumed that was the fuel temp sensor. I would like to know what that sensor is for too plz.
Old Apr 12, 2014 | 04:35 PM
2006GSR's Avatar
Any one got anymore info?
Thanks
Old Apr 12, 2014 | 05:10 PM
jrainwater's Avatar
Fuel vapor sensor according to the part number. I looked it up.
Old Apr 12, 2014 | 05:35 PM
2006GSR's Avatar
What does the line going from the passenger side of the fuel tank to the fuel pump do?
Thanks
Old Apr 12, 2014 | 07:25 PM
jrainwater's Avatar
It siphons fuel between the two sides of the tank.
Old Apr 13, 2014 | 02:45 PM
2006GSR's Avatar
How does it siphon the fuel from the other tank?
I'm a bit confused.
Old Apr 13, 2014 | 03:07 PM
barneyb's Avatar
I'm a bit confused.
Its a jet pump. Works like any jet pump, no moving parts.
Old Apr 13, 2014 | 03:25 PM
Carbonlution's Avatar
the one tank you have has like 2 sections.. both sides of the drive shaft..
the line going from passenger side over til right side is to pump the fuel from one to other side.
and how it does that is with the fuel return line, it makes some type of vacuum in a T- connector where the pump is.. and that sucks it...kind of..
but what the damn sensor is for i dont know..
for me it looks like sensor on the driver side is for Half tanke to empty , and the passenger side from Full tank to half sensor..
Old Apr 13, 2014 | 03:57 PM
2006GSR's Avatar
Reason I am asking. I will be doing a surge tank setup. I will have the oem fuel pump sending assembly send fuel to the surge tank and from the surge tank trough the oem return nipple. I wanted to return it trough the line that siphons from the other side. A bit confusing.
Old Apr 14, 2014 | 12:36 AM
is you want to make a SURGE tank, you need to use the oem tank with its pump TO a surge tank in the back of your car, and the 1 or 2 pumps sending to fuel rail. the return line should then go to surge tank. and a overflow line back to oem tank. and that overflow line must go with the line on passenger side.. haha.. did you get it?
Old Apr 14, 2014 | 06:01 PM
2006GSR's Avatar
I have it all figured out. Just was confused on how the fuel tank worked with all the siphoning stuff. Ima have a oem intank pump feed the surge tank and have it return to the oem return on the fuel sending unit. Then from the tank. Have a -12 trough a 60-100 micron filter to my aeromotive eliminator pump (pump is controlled by the billet controller) and a -10 line to the fuel rain. Right before the fuel rail I'll have a 6micron fuel lab filter. From FPR I have a either -8 or -10 back to the surge tank.
5k6
For Sale - Part Outs
Mar 10, 2017 12:12 AM
5k6
Mar 5, 2017 07:25 AM
razorlab
Dec 6, 2016 08:45 PM
05EV08
May 13, 2016 10:35 PM
Evolved-8
Oct 30, 2013 05:57 AM
