evo 9 feeling sluggish when normal driving
Old Apr 12, 2014 | 10:34 PM
mrm95's Avatar
So it feels like lately when normal driving my Evo feels kinda sluggish. Maybe it's just me but when I go WOT it feels fine. I find myself having to shift at 3.5k rpm instead of 3k or it seems like the car is somewhat hesistant and somewhat has a bogging feeling. Could this be because of a boost/vac leak? Any of you guys experience this? Thanks
Old Apr 13, 2014 | 05:34 AM
sparky's Avatar
Do a BLT 1st.
Old Apr 13, 2014 | 05:38 AM
sparky's Avatar
Is your turbo fitted with the stock MHI IX WGA? Do yo know what WG spring pressure level is at currently?
Old Apr 13, 2014 | 05:54 AM
meckert's Avatar
Its the feds monitoring your driving and scaling back performance until you abide by the law.
Old Apr 13, 2014 | 08:49 AM
TommiM's Avatar
+1 on the Feds. Just wrap some foil around your ecu and on your head and you should be fine.
Old Apr 13, 2014 | 10:39 AM
mrm95's Avatar
LOL!!! Damn Feds. But about the WGA, im actually on a Forge 19 psi adjustable WGA and i know it needs preloaded. could that be why?
Old Apr 13, 2014 | 10:48 AM
sparky's Avatar
Stock metal IX DV?
Old Apr 13, 2014 | 10:50 AM
mrm95's Avatar
Originally Posted by sparky
Stock metal IX DV?
Yup still the stock DV
Old Apr 13, 2014 | 10:54 AM
sparky's Avatar
You always running 28# peak? Or do you have dual switchable maps? That is, more specifically do you strictly run one peak boost level(28#), or do you sometimes run a lower boost, pump gas map?
Old Apr 13, 2014 | 10:58 AM
mrm95's Avatar
I only have the E85 map. Most of the time i dont watch my peak boost though only the wideband. its a bad habit i know lol
Old Apr 13, 2014 | 11:03 AM
sparky's Avatar
Two things that I would suggest: 1) Raise(adjust) the WG spring pressure higher. 2) Crush the DV.
If you want I can spell out the reasons why the two above steps will probably cure the issue. If you want how to on the specific procedures then PM me.
Old Apr 13, 2014 | 11:10 AM
slowsrt4:('s Avatar
maybe check your spark plugs while you're at it
Old Apr 13, 2014 | 03:19 PM
Bhsj13's Avatar
I bet it's the plugs. Make sure you are gapped right.
Old Apr 13, 2014 | 07:15 PM
Awd-se's Avatar
1. Boost leak test- as stated above-first. If you are still running egr then check that first- both vacuum ports seem to pop off pretty easily.
2. Plugs.
3. Wires.
4. Coils.
If plugs/wires/coils have a lot of age on them then it could be a part of it.
Hope you find the cause!!
Old Apr 13, 2014 | 10:20 PM
mrm95's Avatar
Yep they are the original 90,000 miles coils. Plugs however only have about 4-4.5k on them...
In full boost though i dont feel any misfire or anything. could it still be the coils or plugs even if i dont get misfire?
MrJoshH
Jul 9, 2015 06:50 AM
sirchumpalot
27
Nov 28, 2012 12:07 PM
SpeedI2acerX
Dec 9, 2011 12:41 PM
iliketoparty
Dec 21, 2010 01:12 PM
Evo1001
Jun 21, 2010 10:22 AM
