Sponsored by:
Sponsored by: CARiD
1st and 2nd real sluggish --- help
Old Jul 7, 2015 | 06:48 PM
MrJoshH's Avatar
Question 1st and 2nd real sluggish --- help
08 GSR
SYMPTOMS:
-1st gear sluggish and high RPMs (6k only going 10-15mph and sounds like I'm at 9k).
--Second feels better half way through but still a noticeable difference in pull as in 0 pull. Don't notice anything in 3rd and up.
-My exhaust is louder than usual and my car vibrates more than usual in lower gears. I've checked my clutch and its working like a boss and I can't find anything wrong with my exhaust.
Over all just seems like my engine is always being overworked.
Also: The Mitsubishi dealership changed out my drive pulley due to a recall. Would that have caused any issues? Any suggestions would be great!! Thx
Old Jul 7, 2015 | 07:06 PM
hydro334's Avatar
Your clutch is shot.
Old Jul 7, 2015 | 07:32 PM
Napalm_Enema's Avatar
Sounds like clutch is out to me.
Old Jul 7, 2015 | 08:17 PM
MrJoshH's Avatar
I was playing around with the clutch by starting in 4th with the hand break up and it stalls every time. Isn't that a sure sign of the clutch working?
Old Jul 8, 2015 | 07:13 AM
I've never heard of that being a way to test the clutch. I usually tell a clutch is going out by feel.
After searching I think this is what you were trying to test?
Another way to establish if your clutch needs repair is to test it in a parking lot. With it stopped but running, put the car in 2nd or 3rd gear and let out the clutch. If it does not stall, but the RPMs go up and the vehicle does not move, the clutch is bad and needs to be replaced.
http://www.wikihow.com/Diagnose-a-Sl...ch-in-Your-Car
Old Jul 8, 2015 | 08:23 AM
Lightsaber's Avatar
This paragraph from the Wikihow link:
"Another way to establish if your clutch needs repair is to test it in a parking lot. With it stopped but running, put the car in 2nd or 3rd gear and let out the clutch. If it does not stall, but the RPMs go up and the vehicle does not move, the clutch is bad and needs to be replaced."
Is some great information.
Old Jul 8, 2015 | 12:30 PM
MrJoshH's Avatar
Thanks for the input guys. I tested the clutch in a parking lot and this is what happened.
1. For the first test I kept the parking break disengaged. Put it in 3rd and slowly let off the clutch. The car started to move. Once my foot was completely off the clutch the car was moving.
2. With the parking break up the car stalled in every gear once the clutch was fully out.
-- 90% off the clutch in 2nd the rpms go from 300 to 1k followed by a noise and then the car shakes a bit right before stalling.
Does that rule out the clutch?
Could it be the timing chain?
Thanks again for the input.
Old Jul 8, 2015 | 12:33 PM
Man if you haven't changed your timing chain on an 08 with decent miles, I'd do that ASAP. They didn't fix that before 2011 is my understanding. (Timing chain would stretch prior to 2011) I'd change that and see where you sit, and inspect the pulleys they replaced to ensure that was solid.
Old Jul 8, 2015 | 12:39 PM
MrJoshH's Avatar
Thanks, that's was I thought it might be. Glad to hear that it's more than likely my timing chain rather than my clutch. I just ordered a timing chain off a guy from the evox site. Looks like it's going to be a busy weekend for me.
I'll follow up post install and try to make a 'How to' for anybody else with timing chain issues.
Old Jul 8, 2015 | 01:27 PM
hoobastnk90's Avatar
I thought the timeing chain would throw a code though? Yea i also doubt its your clutch usually if just slam it through the gears a few times it would start to slip if it was bad not to mention the test you just did. Also you can test the clutch in a little less harsh of a manor by just getting on the gas in 5th gear from like 50 or 60 mph it would usually slip at that point since there would be a lot of torque put on it.
Old Jul 8, 2015 | 03:42 PM
Yeah it might throw a code if it gets bad enough, I wouldn't wait for an error on a timing chain though...
Old Jul 8, 2015 | 04:44 PM
MrJoshH's Avatar
A few weeks ago I had to reflash my ECU do to my Cobb AP bricking it. I'm thinking that might have tricked the timing chain tension sensor in thinking that the chain is good.
--side note: Out of desperation I changed my spark plugs. Looks like the guy who owned the Evo before me only put two NKG plugs in with two generic brand plugs. Not sure what that could have done. After a test run it seems to be running better; still not normal :/.
Thx thanks and more thanks......
Old Jul 9, 2015 | 06:49 AM
EWWW 2 different plugs.. man what a cheap sob the previous owner was.
Old Jul 9, 2015 | 06:50 AM
Now the question really is why did he change only two? Were they damaged did a piece of it break off and fall into the cylinder... who knows.. Good luck hope you get it figured out!
RedLeader024
Lancer Troubleshooting
Jun 11, 2014 07:00 AM
Rat Fink
May 7, 2012 01:58 PM
SpeedI2acerX
Dec 9, 2011 12:41 PM
gerard
Oct 25, 2008 06:39 AM
5thgenluder
Jun 17, 2008 11:28 AM
