Fuel Pump/ Filter
Old Apr 28, 2014 | 04:03 PM
Ckeesee12's Avatar
Fuel Pump/ Filter
When I purchased my VIII it had a few things previously done to it. One of these things was the fuel pump. I do believe I was told it was a Walbro 255, but am not positive.
Anyways, I am looking at replacing the fuel filter, because my car is almost at 100k miles, and I want to do it as maintenance. Does the OEM filter fit onto an upgraded fuel pump? or Are they specific filters for the pump?
Thanks
Old Apr 29, 2014 | 08:12 AM
mrfred's Avatar
The thing on the end of the pump is not the actual fuel filter. Its just a strainer. Its called a sock, and replacement Walbro socks are readily available from many places.
Old Apr 29, 2014 | 02:11 PM
Ckeesee12's Avatar
is there an actual fuel filter? I'm getting symptoms of a gross fuel filter, a little studder on first gas. Then it goes away for the day.
Old Apr 29, 2014 | 02:33 PM
mrfred's Avatar
Its built into the white (yellow after a while) pump carrier. There is no way to replace it. Instead, the entire pump carrier has to be replaced. I think they are around $150.
Old Apr 29, 2014 | 03:18 PM
Ckeesee12's Avatar
Thank you sir!
jrsimon27
39
May 25, 2022 04:26 PM
Seidelly
May 9, 2016 11:15 AM
Seidelly
Apr 4, 2016 10:26 AM
Hotsauce101
Jul 23, 2015 11:57 AM
kosteniuks17
Feb 17, 2014 08:28 PM
