I stripped a valve cover bolt thread
Old May 8, 2014 | 04:34 AM
Bladey's Avatar
Hey all i was changing my plugs and upon install i seemed to have stripped a thread reinstalling my coilpacks its this exact one ( and yes i was using a torque wrench 17 in-lb)
Well the thread is gone i can get thing bolt in there just a bit tighter than hand tight and all the other bolts are tight so there is no movement in the coilpack
Now to my question should i leave it as it? Should i drill out the Valve cover and tap it or should i helicoil it?
I've never tapped anything in my life and nor do i own a tap set should i jsut cut my loses and take it to a shop and get them to helicoil it?
If it makes any difference im thinking of buying a SpoolinupCop in the next few weeks anyway so will that bolt even be needed?
Cheers in Advance
Old May 8, 2014 | 05:40 AM
egis's Avatar
i have stripped in two places each by coilpacks.since there's 3 bolts holding each coilpack i left it like that and no problems.
Old May 8, 2014 | 06:07 AM
GSXPimp's Avatar
Made me laugh haha anyways I think you should be fine, if you owned a die and tap set I would say do it but I think you will be ok
Old May 8, 2014 | 07:25 AM
heel2toe's Avatar
^LOL poor guy...one of these days...
If I were you I would buy a tap and dye set and helicoil it. Remove the vc and drill and tap it. It's not that hard so as long are you take your time and are very careful you'll be fine.
As for switching to a COP I'm not exactly sure but I think that is one of the two mounting bolts that are needed to mount the plate. If you're planning on purchasing one soon maybe you can hold off until you get it and check to see if that bolt is required. If it is then obviously you'll need to fix the threads and if not then you'll be good to go.
Old May 8, 2014 | 07:41 AM
SL0\/\/*B0Y's Avatar
Tapping the valve cover is not going to be very hard at all. I think the most difficult part in some instances* is trying keeping the metal shavings from falling-but you can take the valve cover off. Also, like "egis" said, there is more than one bolt holding the coil on.
Old May 8, 2014 | 08:21 AM
llDemonll's Avatar
this is correct, that's one of the standard bolt holes for securing the plate
Old May 8, 2014 | 01:30 PM
slowsrt4:('s Avatar
no big deal here
Old May 8, 2014 | 10:45 PM
Bladey's Avatar
Cheers i think i'll take the VC off and get it rethreaded after my tune becasue i was taking it off then to get powder coated
Cheers everyone
Old Jun 2, 2014 | 11:23 PM
555R's Avatar
What would the helicoil part number be to use the oem bolts. I need to do this too. Too many spark plug changes and finally wrecked almost all the threads.
Old Jun 3, 2014 | 09:19 AM
llDemonll's Avatar
how are you guys ruining threads? lol
Old Jun 3, 2014 | 09:27 AM
gsrboi80's Avatar
I have one blot stripped out after hundreds of plug changes. I'll fix it someday. It's not effecting **** at this point so...
Ferp
Jul 11, 2016 08:07 PM
Corbin09
Jan 4, 2013 06:52 PM
boostnMA
Oct 26, 2012 07:21 PM
EvoNyMR136
10
Nov 17, 2011 08:33 AM
MR Turco
Oct 20, 2009 03:39 PM
