Looking for insight on the cooling system
Old May 14, 2014 | 07:49 PM
LetsGetThisDone's Avatar
If you were flexing the block bad enough to push freeze plugs out, it would lift the head. Regardless, racecars run stiffer durometer bushings, or even solid mounts, so that point is moot. If anything, you need to replace your rear mount so it's the same as the others...
Old May 15, 2014 | 07:01 PM
ch53avitech's Avatar
I would actually consider doing this. I mean, how much worse can cabin noises get? lol
Old May 23, 2014 | 08:52 PM
I found out today the my TPS is off quite a bit. It was reading 3.2% at idle instead of the factory 13.3%. That is fixed now. Could that have somehow caused detonation enough to lift the head just enough to blow the freeze plugs but not enough to cause any significant damage?
Old May 24, 2014 | 10:25 AM
bump
Old Jun 15, 2014 | 03:50 PM
Just replaced the TPS sensor as it was throwing a P0120 code. Did 3 pulls on the dyno and 3-4 street pulls. Everything stayed together. Any chance a TPS sensor giving erratic throttle position readings will cause glitches in the matrix and cause detonation to blow out plugs?
Old Jun 15, 2014 | 06:27 PM
I'm pretty sure the computer uses the tps as part of the load calculation, so if it changes after the car is tuned, it can cause improper fueling and timing..
Old Jun 15, 2014 | 06:48 PM
mrfred's Avatar
It doesn't.
Old Jun 15, 2014 | 07:18 PM
Originally Posted by mrfred
It doesn't.
Well could you explain what you think is happening? Honestly, the TPS sensor seemed to do the trick. How could it cause that?
Old Jun 16, 2014 | 04:09 PM
Well I just did a 2-3-4 gear pull up to 9k rpm and everything held together so I'm blaming the TPS sensor for all my freeze plug problems. Can someone enlighten me on how a bad TPS sensor can blow freeze plugs?
Old Jun 16, 2014 | 09:35 PM
batty200's Avatar
Were the freeze plugs original or were they replaced when the motor was rebuilt? The reason I ask is I have never heard of ORIGINAL plugs popping out. I don't think people are installing them as well as factory. Whether it is because of some debris left in the block from old plugs or installation methods I don't ever let anyone put new freeze plugs in any motor of mine. A popped plug is very dangerous especially at the high speeds that they seem to pop at.
Old Jun 17, 2014 | 05:36 PM
I believe the plugs are original. The block went to the machine shop so I don't know if they take them out or not.
Old Jun 17, 2014 | 06:14 PM
Biggiesacks's Avatar
what you had for lunch that day probably had just as much to do with your freeze plugs popping out as your tps did. If your cooling system overall was being over pressurized it would pop your radiator cap. So perhaps you have some kind of blockage that is causing excess pressure to build up in the water jacket at high rpm. It also wouldn't be a bad idea to check your radiator cap for proper operation.
Old Jun 17, 2014 | 11:08 PM
Thanks a lot for the clarification. I'll have to look into this issue further.
It's weird and bothering me. Sometimes I get on the gas a little bit, just start to build boost, and pop a couple plugs.
Other times I beat on the car, dyno pulls, 2-3-4 gear pulls, ect., and the car seems perfectly fine.
3bar_dc2
13
Jul 1, 2016 02:04 PM
ridenrunwv
Jun 10, 2015 10:41 AM
PromDizzle
Dec 11, 2013 05:35 PM
jtyler
18
Aug 13, 2010 09:31 AM
dsevo
Dec 1, 2009 09:31 PM
