Broke Rear Diff on Evo5GSR can Lancer GSR Cm5a rear diff work?
Old Mar 13, 2015 | 09:03 AM
Llew's Avatar
AYC stock evo5GSR diff
Lancer GSR CM5A 1996 Diff
GSR(cm5a) diff installed on EVO5
Old May 20, 2015 | 01:07 PM
Mauricio Evo IV's Avatar
Hello man, hows your swap??? The cm5 is a Lancer gsr 1,800cc right?
I´m in the middle to put a new rear diff in my Evo, but my budget its too low Here in my country I dont have many options, only to bring it a Evo 8/9 rear diff from USA but i like said, its expensive... Do you lnow other way to kit in my Evo 4 (rear diff ratio is 3.312). Maybe an Outlander rear diff?
Old Nov 2, 2015 | 03:50 AM
masheer's Avatar
Liew....any update your evo using cm5a rear axle...still work in good condition?....
Old Jan 22, 2018 | 10:41 AM
Llew's Avatar
Still works great after lots of drag racing and autox . Had to rebuild the motor twice, had to change turbo once, clutch twice, 3-4th shift fork , engine mounts, diff mounts but still havent had to change the GSR rear diff or even change the oil as yet. Still works great. very tricky to try to power slide with though...but ive managed to get used to it and even beat rally cars arround some courses.
Old Feb 4, 2019 | 08:18 PM
Ivar Oehlers's Avatar
Diff howling noise
I have a 98 evolution V GSR model with ayc. Rear diff is damaged and a used e5 diff costs $2500 in my country. I have a rear diff LSD from a 97 Lancer GSR 1800cc CM5a model readily available to me for free. Can this work? Also the previous owner has changed the final drive in my GSR gear box to the RS final drive 4.529 to 4.875.
GSR CM5A gear ratio
MPH
1st gear ratio 3.583
2nd gear ratio 2.105
3rd gear ratio 1.407
4th fear ratio 1.031
5th gear ratio 0.761
Rear gear ratio 3.416 MPH154@7000 160@7500
Top gear ratio 0.76
Final drive ratio 4.11
Evo 5 GSR gear ratios Standard
1st 2.785
2nd 1.950
3rd 1.407
4th 1.031
5th 0.761
rear diff: 3.307 not sure but found this online
Final Drive: 4.529
My car has approximately 380-400whp and I do drag race it and launch it very hard
so i recently changes my rear diff bushings so afther i got my car back e hear this howling noise from the
back of the car (evo6 gsr)specialy in 4th gear and 5th when i press the clutch it slowly goes away so i was wondering what this could be?
Old Jan 23, 2021 | 02:40 PM
knox839's Avatar
Cm5a
Hello Llew, I’m also swaped a cm5a (helical lsd diff) rear end to my cp9a evo 6 gsr with ayc rear end (ayc diff broken). What I want to ask you, do you know if evo rs lsd fits inside the cm5a rear diff casing ? If it can fit, it will be perfect. I will just buy rs rear diff or may be cusco and install inside to cm5a rear end. Thanks.
Old Nov 19, 2025 | 06:38 PM
VVK's Avatar
VVK
I’m looking to buy this diff out of a CM5A 1.8 GSR manual, my Evo 5 GSR still has AYC. After doing some research, people say this style diff is the same as Evo 1-4 and Evo 5-9 mounting points are different. Can someone confirm it’ll fit a Evo 5 too?
cha951
May 2, 2022 10:28 AM
cming21
Feb 18, 2022 08:48 AM
Richiexoxo
Jul 14, 2017 04:31 AM
Llew
May 21, 2014 08:43 AM
