Wiseco ring gap
Old May 26, 2014 | 03:22 PM
Schia89's Avatar
Wiseco ring gap
I'm wondering where to gap the rings on a motor I'm building
It's a 86mm wiseco 9:1
Power we're shooting for is 550-600whp
Old May 28, 2014 | 02:28 PM
Schia89's Avatar
Anyone?
Old May 28, 2014 | 05:40 PM
diambo4life's Avatar
0.018-0.020" (top)
0.020-0.024" (bottom)
Old May 28, 2014 | 05:59 PM
JohnBradley's Avatar
Bore size in inches x 0.0050 for top ring (starting point)
Bore size in inches x 0.0055 for second ring (starting point)
Old May 29, 2014 | 06:17 AM
Schia89's Avatar
Thanks guys...saw this a little too late haha
I ended up goin .20 top, .22 second
I decided to go on the looser end
Old May 29, 2014 | 06:19 AM
Brianawd's Avatar
I would open up that 2nd ring a little
Old May 29, 2014 | 04:58 PM
Agreed. You don't want ring flutter.
Old May 30, 2014 | 09:08 AM
Schia89's Avatar
I'll definately do that
I'm goin open it up to .024
Thanks a lot guys
Old Aug 13, 2014 | 08:45 PM
real fast's Avatar
This info is right from wiseco using 1400 HD pistons
top ring between 17 - 21
second ring between 19 -26
piston to cyl wall clearence 3 to 4.5 max
I'm building my motor as we speak and the second ring is set at 28 and I didn't even touch it..I'm std bore and using piston 6626m85...So i'm going to set all the second rings to 28 and the top ring to 22..looser is better then tight if your going high boost.
Here's a pic of a friends pistons on his 2003 evo using wiseco 1400HD .20 over....i took the motor apart the top ring was gap to 9 thousand and the second ring gapped at 20..Ring gap is very important ..alot of people and machine shops just slap motors together blind
kaj
22
Jan 27, 2019 12:23 AM
tscompusa
158
Jan 17, 2017 02:52 PM
cerevo
12
Sep 9, 2016 03:45 AM
kylefowlie
Dec 21, 2015 11:54 AM
06mr775
10
May 15, 2013 08:09 AM
