Fuel Chilling System
Old Jul 2, 2014 | 09:16 AM
foxbat's Avatar
http://www.designengineering.com/cat...hilling-system
Has anyone used this kit before? Is it any good?
Old Jul 2, 2014 | 09:53 AM
Biggiesacks's Avatar
If I'm not mistaken, these types of things are banned in most motor sports. I don't know why, but I'm sure there is a good reason for it.
Old Jul 2, 2014 | 11:52 AM
ReaperX's Avatar
I would shy away from something such as that. It must be pressurized in the holding tank to at least 60psi to maintain a liquid state, and if something in the system were to fail it could mean bad news for you and the car (depending on where you mount it). I would just go with straight water injection if your a track rat, or water/meth for non track purposes before even considering this.
Old Jul 8, 2014 | 08:25 AM
mrfred's Avatar
unless your fuel system is getting overheated due to operating the pump at 100% power all the time or due to bad fuel line or fuel filter placement, no cooling should be needed.
Old Jul 8, 2014 | 04:59 PM
Andrew b's Avatar
Fit a fuel cooler on the supply line
Old Jul 8, 2014 | 07:08 PM
Grimgrak's Avatar
Or you get the aeromotive variable voltage pump power .
Old Jul 8, 2014 | 07:20 PM
mrfred's Avatar
Or just use the factory dual stage power supply.
Old Jul 9, 2014 | 07:24 PM
mouseIX's Avatar
Colder fuel is better. On Porsche 996/7 turbos the fuel line is wrapped with the low side AC line before it enters the rail. Similar concept but it uses the existing AC equipment to chill the line. Even if it's not getting "hot", if you can get it colder the better. Will you notice a difference? Probably not. There are many other modifications before requiring a fuel cooler.
Old Jul 10, 2014 | 12:11 AM
mrfred's Avatar
Everyone is looking for an edge, but this isn't it. The insignificant change in fuel density doesn't offer any benefit. Maybe something can be said for the cold fuel cooling the intake charge, but hard to imagine that it helps. Better to just focus on trying to keep the fuel from getting hot.
Old Jul 10, 2014 | 06:25 AM
mouseIX's Avatar
True. I agree not necessary for this application. But every edge helps and cooler fuel isn't a tall tale. I will try and find back to back dyno charts for a GT3 Cup we played around with a few years back. IIRC horsepower didn't fall off as drastically with heat soak, which for an enduro car, helps. First pull was identical, but by the third pull the none fuel cooled runs were loosing power at a more rapid rate. Just food for thought, and I understand a GT3 cup is way more refined than a DD Evo.
SKY888
May 8, 2018 01:44 PM
NJ_evoIXgsr
Mar 2, 2017 06:56 PM
NJ_evoIXgsr
For Sale - Cars For Sale
Feb 11, 2017 10:38 AM
Jrod@Buschur
Apr 21, 2010 08:01 AM
RAswish
May 11, 2009 02:03 AM
